Can I match Google Traffic from MPLS to oversea?
WilliamQin
Hi  Everyone
I have one internet and one MPLS, I tend use MX100, Then put internet and MPLS in the MX100, I have some needs
Can I how to match Oversea traffic on the mpls link out.
For example : I have access google.com or facebook in china, I want match Google and Facebook traffic to MPLS,
How do I configure it ?
4 REPLIES 4
I don't understand what you want to achieve.  What do you want to do with this matched traffic?
Are you want to block traffic based on the country it came from?
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/Firewall_Settings#Geo-IP_Based_Fire...
hi Phili
I have MPLS from China To USA, aslo have a internet,
We cannot access google use internet in china,So I just want match Google traffic into mpls to USA, Then I can access, I want match some oversea traffic into MPLS, Then I can access google. But some china traffic
I want use internet go out.
Hope you know what i mean, Thanks A lot.
What you probably want is a squid proxy server in each country that uses the local Internet connection.  Then use a WPAD auto-proxy config file to direct browsers to either the local or remote proxy server based on the domain being accessed.
@PhilipDAth Sounds like he wants to use his MPLS connection to bypass the great firewall of China.
www.btr.net.nz
