16.4 Beta - breaks Whitelisting and content filtering.
DarrenOC
Jumped straight in and upgraded my Home/Lab MX to 16.4 (using an MX68).  Upgrade was smooth as expected.  Went through each dashboard page to see whats new.  All checked out fine, could see the new Anyconnect Beta feature - excellent, alls well.
Started browsing, tried to log into LinkedIn.....blocked, Facebook....blocked....hmmmm
Reviewed the event log, my device is being blocked due to content filtering.  My device and some others are whitelisted.
Removed the social media content filter - straight out.
Removed all content filters, set all devices back to Normal.  Then reverted back to blocking content and whitelisting my device.  Broken
@MeredithW @CarolineS - can we feed this back into the relevant BU?
Darren O'Connor | uccert.co.uk
9 REPLIES 9
Adam2104
I believe this is listed in the release notes as:
Known Issues
  • Group policies do not correctly apply to client devices
DarrenOC
Hi @Adam2104 , I have no individual Group Policies setup and applied.  Unless Meraki are stating that Device Policies are also affected
Adam2104
I may be mistaken, but I believe those pre-canned policies to also be group policies, just not custom-defined ones.
@Adam2104 you may be correct but if the Allow list etc. are Group Policies then why are they all on a menu called Device Policies?  Wouldn't the menu be called Group Policies...
DarrenOC
Group, Device....its just broken 😂🤣
Going to leave on the Beta for now so I can play with Anyconnect
MeredithW
Community Manager
@DarrenOC sent! If you haven't already, please do also file a ticket with support about it!
Meredith W | Community Manager, Cisco Meraki
Found this helpful? Give me some Kudos! (click on the little up-arrow below) New to the community? Get started here
My approach to firmware upgrades is let @DarrenOC try it first and find all of the faults 🤣
www.btr.net.nz
🤣unfortunately @DarrenOC normally waits for me to upgrade first, though I think he might have jumped first on this one...
DarrenOC
You’re not far wrong there Charles.
I see all your devices go down, come back up. If you don’t roll back I know it’s good 😃
