Z3C (Disabled gateway bad connectivity)
NorwegianFrog
My company has recently set up over 150 units of Z3C's across the country, and in some destinations we get these messages 'Disabled gateway bad connectivity'. Now in the example above, it's a bit weird since the signal strength is good(3 out of 5 lines), and the speed in general is like 50down and 15up, so it's not in a bad location.
So the question is, why is this happening in some locations, and others not? Is there a fix to this? The firmware of the Z3C's are MX16.8.
Accepted Solutions
UCcert
Re: Z3C (Disabled gateway bad connectivity)
hi @NorwegianFrog
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/Connection_Monitoring_for_WAN_Failo...
"The MX then begins performing the internet test. If either the ICMP or the HTTP test is successful, the internet test is marked as good for 300 seconds on that uplink. During this time, the MX continues running the internet test every 150 seconds. Each successful internet test (meaning either a successful ICMP test or a successful HTTP test) results in the internet being marked as good for another 300 seconds. If any test within the internet group fails, the MX decreases the testing interval to 20 seconds. If the tests continue to fail for a time period exceeding 300 seconds from the last successful test, the internet will be marked as failed on the uplink. Otherwise, any successful ICMP or HTTP test will mark the internet test as good for another 300 seconds. Once marked as good, the test is run every 150 seconds."
Darren O'Connor | uccert.co.uk
5 REPLIES 5
UCcert
hi @NorwegianFrog
This is explained within other posts:
https://community.meraki.com/t5/Security-SD-WAN/Meraki-showing-Bad-Gateway-no-internet-connectivity/...
https://community.meraki.com/t5/Security-SD-WAN/Teleworker-Z3-14-53-Bad-Gateway-Event-Log/m-p/94088#...
Any logging in the event log on that times? For example change of lte channel?
You could try run latest 16.12
or 15.44 if you dont want beta
NorwegianFrog
I would assume it has something to do with the ISP then.
I've noticed on some other locations where the Z3C will lose connectivity, but will pick it up after 1-5 minutes. Do you know how it works when they do lose connectivity? Is there a time limit on how long they're trying to reconnect?
NorwegianFrog
Well I get a lot of different ones, not sure which one are relevant.
Here are a few:
Route connection change - This is when I think it lost connectivity, around that time.
VPN registry connectivity change - During no connectivity
Primary uplink status change - When I think it got back.
UCcert
hi @NorwegianFrog
