Dashboard Problems
TRBO_KCMO
Dashboard Problems
Our dashboard just started acting up. It's duplicated itself. We can't even get to a help screen, as the ? button doesn't work.  Just started around 3:52 central. This happening to anyone else?
CarolineS
Meraki Alumni (Retired)
Per status.meraki.net, this has been resolved:
Incident resolved - A fix for the rendering and navigation issues with Meraki Dashboard has been rolled out and verified. Meraki Dashboard is now operating as expected. If you experience further issues, please don't hesitate to contact Meraki Support.”
13 Replies 13
TRBO_KCMO
Crocker
Same problem here. Coworkers also reporting the problem.
Yes, it looks like all of the code that normally hides elements and allows you to select items has gone AWOL so everything is just shown all at once!
Meraki Status acknowledges the problem and the fix is being deployed.
nbv
Same thing here at about the same time. I didn't have time to look at it much earlier and thought it was a formatting refresh similar to the Community site here. Looking closer at it, it appears that something might've broke.
Lumen-Sebi
same here
SPeacock
Me too.  Super difficult to use it this way so I guess it's time to work in Meraki tomorrow 🙂
MattyK
Not exactly what I wanted to see when logging in this morning. looks like the Styles.css has gone missing.
Yousif89
Checked https://status.meraki.net/ already report issue
TRBO_KCMO
Looks like they just fixed it
SergeVan
Same here!
CarolineS
This issue is now being tracked on https://status.meraki.net/ - please subscribe there for updates.
I’m going to mark this reply as the “solution”, for visibility. Will update when the issue is resolved (but status.meraki.net is the best source of info)
SteveWeidner
I'm seeing the same issue for the past couple of hours in both Chrome and Firefox.
CarolineS
