which switch 24 with PoE capability 740W
IMustafaSaleh
Hi folks!
I need Meraki switch 24 with PoE to support 19 IP phone, which model can support? because I cannot find any 24 port switch support 740W.
Your advice please.
You are highly unlikely to need 740W in a 24 port switch to support phones.
A typical phone uses 7W.  7W x 24 ports = 168W.
Maybe a super hungry phone with a video display might use 15.4W.  15.4W x 24 = 370W.
740W / 24 ports = 30W per port.  That's like half of an old school incandescent 60W light bulb.
It will be a mistake.  You won't need that kind of power.
5 Replies 5
Gumby
What phones are they?  That seems like an awfully large power draw for IP Phones.
You might need to go to a 48 port FP model.
Kamome
According to spec sheets, MS355-24X2 can support 720W PoE.
https://meraki.cisco.com/wp-content/uploads/2020/05/meraki_datasheet_ms355.pdf
merakichamp
@IMustafaSaleh   i think ms 355 can do  and of course the one powerful ms 390 can very well give you that capacity
IMustafaSaleh
Thanks @PhilipDAth. I reviewed the power consumtion and 370W will be enough.
