Hi there
Please can someone explain to me the function of an MS switch's management interface VLAN field (found within a switch's LAN IP settings pane):
Is it in reference only to switch-to-dashboard traffic (information the switch needs to communicate to dashboard and vice versa) or to management traffic in the sense of STP/RSTP, CDP etc
What type of traffic will the switch "tag" with whatever VLAN is specified in that field?
Also, is this field any different to the Network-wide "Management VLAN" field you can specify under: Switches > Switch Settings.
Anthony
