Where to find vlan summary in Meraki MS220 siwtch?
Merakibgp
Hi In Meraki switch MS220 page, we can see the summary of all of its ports, but I cannot see its vlan status or its summary. Does it have the summary for its vlan? and can we use command line for configuration? Thanks
Adam
There is no equivalent command or CLI.
If you just want to see a list of the VLANs you'd go to
Security Appliance>Addressing and VLANs
or
Switch>Routing and DHCP
If you want to see what ports are in specific VLANs then you'd want to go to Switch>Switch Ports and search/filter accordingly.
9 Replies 9
no command line.
go to switchports. pres the + to add more columns and select vlan. you can use the search to filter on vlan or tags or duplex etc
Adam
Or if you want to see all ports in a given vlan you can go to Switch>Switch ports then click the drop down box in the search window and input the vlan number.
Merakibgp
Thanks for your reply. I want to see vlan summary. it looks like Meraki does not have it, right? In Cisco, it is show vlan.
Maybe we can see it in layer 3 switch
Adam
or
Merakibgp
I found "Security center" which is located under Organization, but i could not find "Security Appliance>Addressing and VLANs". Where is "Security Appliance"?  Can you tell? Thank you!
You can see layer 3 VLANs, because they have an IP address configured on them - but there is no where to see a list of all the configured layer 2 VLANs.
Merakibgp
we do not need to create vlan in Meraki switch like Cisco switch. as long as we assign a vlan to port, the vlan already is created. i am right?
That is correct.
BlakeRichardson
@Merakibgp this might help you.
It generates a view that looks like this
