Switching from MS220-48FP to MS120-48FP
Riser
We are looking at switching from MS220-48FP to MS120-48FP. Currently, we have 8 MS220-48FP on our network. Is there an easy way to effect this change and move all the settings at once from the existing 8 MS220-48FP to the new 8 MS120-48FP?
Of course, it will take time to configure all the port settings individually. Any suggestions will be appreciated.
11 Replies 11
Clone the actual network and add the new switch in the new network cloned.
Riser
The reason why I didn't want to move with the option is that the same network has 3 MS225, which we will be retaining. Cloning the entire network will mean cloning the same settings for the 3 switches, which will still be retained, right?
You can configure via the API as mentioned, but I find it so easy to configure via the dashboard that working on a script to configure via the API is an unnecessary waste of time.
Just configure from scratch and that's it. Meraki is too easy.
Ryan_Miles
Meraki Employee All-Star
Cloning a switch network won't bring over any port configs so this isn't an option
For switch ports i would use the api to get the ports configs. Then put the to the new switches
https://developer.cisco.com/meraki/api-latest/get-device-switch-ports/
BlakeRichardson
Depending how populated the switches are just do it by hand. You could export your existing port config as a CSV and just work through it that way plugged each thing into it's own spot.
The beauty of Meraki is if you muck a switch port up it's usually very easy to identify whats connected it it via the client info either on the switch port itself or network wide page.
DarrenOC
Agree with @BlakeRichardson , by the time you’ve written the API you could have installed and configured the replacement switches
I don't think it will allow it - but try the switch cloning tool.
https://documentation.meraki.com/MS/Other_Topics/Switch_Cloning
Ryan_Miles
Switch cloning requires source & destination switches to be the same model https://documentation.meraki.com/MS/Other_Topics/Switch_Cloning
I have found Google Bard quite good at writing scripts to do Meraki changes.  Perhaps give it a try.
https://bard.google.com/
KarstenI
How many *different* port configs do you have? With virtual stacking, you can configure hundreds of ports simultaneously, and the new Port-Profiles (still beta) would make It even easier.
