I plan to deploy Meraki MS switches in a building, where we plan to build stacks for each floor.
One floor should be based on 2x MS390 switches which will be stacked.
All other floors should be based on 2x MS225 switches per floor which also will be stacked.
We have experience regarding MS225 stacking, but it's our first time to stack MS390 switches.
After some research we discovered following note from Cisco:
MS switches other than the MS390 have one active switch in the stack and all other switches are member switches. MS390 stacks also have one standby switch. The standby becomes the active unit in the event of a failure of that switch.
Source: https://documentation.meraki.com/MS/Stacking/Switch_Stacks
Could someone further explain what this description means?
Is the 2nd MS390 member fully in standby and not able to send data?
Thanks a lot and best regards
