Request
ed_237
Request
Hello All,
I have some particular specification about using an equipment. After many research, I found out i can use the Cisco
MS130-12X.
But I dont know how cisco meraki equipment works.
Can I manage it without using meraki cloud dashboard?
Is there a possibility to manage it locally without internet connection?
Thank's in advance tou your responds.
kind regards
Brash
As with all Meraki devices, the MS130-12X requires an internet connection to manage and configure. It also requires purchasing a license alongside it.
You may also want to check out some of the following resources to get started:
https://documentation.meraki.com/MS/MS_Quick_Start
https://community.meraki.com/t5/MS-Fundamental-Implementation/ct-p/MS-Fundamental-Implementation
Brash
CarolineS
Community Manager
Community Manager
Community moderator here. Marking this reply as the solution for better visibility!
Caroline S | Community Manager, Cisco Meraki
Inderdeep
Its managed through Meraki Cloud and needs internet to reach to portal.
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
