Does Meraki Switces support ISCSI?
AnkitSharma1
Can we use the Meraki Switches ?
Mloraditch
In general yes they do but depending on your exact scenario you will want to look at the specs necessary for your storage device and then compare with Meraki's performance for the models you have or are looking at.
For simpler storage devices you will probably be fine, if you are getting into enterprise SANs, I'd be looking at dedicated storage switching from the regular Cisco product line.
AnkitSharma1
We do have DellEMC storage that uses ISCSI
Inderdeep
Yes it is supported
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
GIdenJoe
iSCSI runs on IP.
IP runs on ethernet.
Meraki switches are ethernet switches, so this will work just fine.
There is in fact nothing special about iSCSI switches...but for a way of the server vendors to sell their gear.  The only thing that can matter is the performance of the switch.  Which means, uplink bandwidth, oversubscription and buffer sizes.  Meraki switches are aimed and access layer and not exactly datacenter so the buffers won't be the biggest but if you make sure you design with the correct port speeds, the buffers shouldn't be an issue.
