MS130 Virtual Stack
M_Faizal
MS130 Virtual Stack
HI,
Does MS 130 supports virtual stack?
I dont see MS130 listed under stacking cables in the below link.
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Small-Form_Factor_Plu...
Regards
MF
GIdenJoe
I believe the true Meraki lingo has always been:
Virtual stacking = just putting all the ports on one page (great feature, but nothing to do with the switches itself)
Physical stacking = backplane stacking with two cables
Flexible stacking = having switches transform regular ports into stacking ports which in Cisco classic is actually called virtual stacking 😜  Lovely confusion there.
Mloraditch
Virtual stacking is nothing more than a marketing name for the dashboards ability to edit every port in a network at once using the switch port settings page.
Physical stacking requires dedicated cables and the MS130 do not support that.
DarrenOC
A bit like “zero touch” deployments @Mloraditch
GIdenJoe
CarolineS
Community Manager
Community Manager
Thanks for this answer, @GIdenJoe! I'm marking it as the solution. @M_Faizal - if this does not answer your question, please let us know what further clarifications you need.
Cheers!
