- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Replace a Switch
Hello everybody.
I have to replace a Switch with a fan fail and I would like to know more about the replacement process.
Are these the steps to follow?
- Remove the damaged device and unclaim.
- Add new device and claim.
- Clone de new device.
Can I clone a new switch using the previously removed switch configuration?
Is the configuration still available?
Thank you.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @jlopez_sv81
Documented process here:
https://documentation.meraki.com/MS/Other_Topics/Switch_Cloning
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
but, is the configuration still available after removing of network the damaged switch?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @jlopez_sv81 , as stated by @Dylan_YYC , clone first then remove from Network.
You won’t lose any switch config.
Completed a zillion times. Works a charm.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
So the steps are
1. Claim the New switch - which I got via the RMA Process and Add to the Network.
2. Clone the Bad Failing Switch to the New Switch
3. Remove the Bad Switch, and Unclaim it from Inventory
4. Mail the Bad Switch back
