Meraki MS switches interoperability
StormTrooper
Hi all,
Has anyone used Cisco SFP-10G-SR in Meraki MS-400 series switches ?
I know they are not on the certified list, just wondered if anyone has tried them and used successfully.
I have never tested it, but I have been told that Cisco Meraki kit does not check the manufacturer ID burned into the SFP ROM (unlike Cisco Enterprise kit which does).
5 Replies 5
Ben
We used the meraki sfp modules on a Zyxel switch and they worked just fine. So I would say give it a go.
Worst case : no connection..
Cheers
Ben
pinchusg
I’m using from Fiberstore $16 SFP modules on MS225 and MS250 switches and they work fantastically.
PS_Mike
I also use Fiberstore SFP modules in my MS350 switches as well as my MX250 firewalls. No problems.
redsector
I have got Cisco SFP-10G-SR-C SFP´s working well in Meraki MS225-48LP.
