Meraki MS-125 Unable to access Local Status Page
Mike05
Hi Masters,
Just want to ask if somebody encountered the issue I am facing with MS125-48 switch.
Currently, I can't access the local status page so that I can setup proxy settings.
I've tried below.
* Laptop set to obtain DHCP.
1. Connect LAN cable to dedicated management at the back of the unit.
2. Check IP address - none (APIPA).
3. Tried to access switch.meraki.com ; my.meraki.com ; setup.meraki.com - all failed.
*Laptop set to 1.1.1.99/24
2. Tried to access 1.1.1.100 - failed
3. Ping 1.1.1.100 - failed.
Together with this unit are stacked MS350-24X, the local status page pops up automatically upon connecting to management port so it's just the 3 x MS125-48 that I'm having trouble.
Any ideas?
TIA,
Mike
8 Replies 8
Did you try on a switch lan port, combined with static ip address on the client
KarstenI
There were a couple of Release/model combinations where the Management-port didn't work for the local status page. Have you also tried a LAN-port for this?
Mike05
Hi @ww , @KarstenI ,
Thank you for your response.
Initially, I added and managed it in the Dashboard so I'm able to change the IP address from there.
Its just that during the deployment, I was informed that customer by default has no internet unless you use proxy.
I set the IP Address in 172.26.x.x subnet, in this case, should I connect to normal LAN port then access http://172.26.x.x?
Regards,
Mike
Mike05
Hi @ww ,
Understood, so meaning I still need to access it based in the original management IP.
I'll give it a try when I go onsite tomorrow and give you a feedback.
Thanks,
Mike
BlakeRichardson
@Mike05  Is local management page access enabled in your dashboard as its something that can be disabled.
Network-wide > Configure > General
Mike05
Hi @BlakeRichardson ,
I will explore this option, I'm still new in using Meraki Dashboard 🙂
Regards,
Mike
Mike05
It works!
So that's the way in case I can't access using dedicated management port.
Anyway, thanks to all of your replies.
Regards,
Mike
