Hello.
It seems that there are many intermediate SWs for the purpose of port conversion.
If the access is "x100", is it 2000 ports? Well, you should prepare the necessary number of L3-SW.
I'm going out so I haven't seen it in terms of load balancing/MLAG links. (Personal impression.)
Regard,
有用な回答だと思われる際にはkudoをクリックして頂けると幸いです。
回答があなたの問題を解決した場合、accept as solutionをクリックしてください。
