Cabling / Connectivity suggestion
Raji
We have ordered only 3 SW's - MS210-48FP connecting with 39 Cisco Phones.2 going to be stacking at Ground Floor & 1 SW goes to 1st Floor, Please advise the following
Cabling part between Stack Switches and 3rd Switch ?
Ground & First floor SW required separate WAN Link ? or we can connect WAN to Stack Switches from there we can connect to 3rd Switch?.
It's just an example, ok?
https://documentation.meraki.com/Architectures_and_Best_Practices/Recommended_Topologies/MX_and_MS_B...
8 Replies 8
You don't need a separeted WAN Link, plug any one of the Ethernet or fiber ports into an upstream device on your LAN. The uplink port should have access to a DHCP server and it will also need to be able to communicate with the internet.
Raji
Thanks for the reply !
So the connection part would be WAN link to Meraki Stack Switch's at the ground floor from there we can connect to 3rd Switch ( 1st Floor ) ?..
Yep, the switch only needs an IP address and it must be able to communicate with the Meraki cloud.
Raji
Thanks for the reply Sir !
So the connection part would the Uplink device ( WAN Link ) to Meraki Stack SW's at the ground floor from there we can connect the cable to 1st floor Meraki SW  ?. Pls suggest
Raji
Thanks a bunch Sir !, Is the same applicable for Stack Switch ?
Raji
What kind of cable we may use between ground floor Stack Sw to 1st floor SW and length of the cable generally prefers ?.. Pls advise
https://enableit.com/how-long-can-an-ethernet-cable-be/
