Cisco 9300 booting in meraki mode
Thijo17
Hey all,
I do have a brand new 9300 that's booting into meraki mode and it doesnt allow us to do nothing with it. My question is:
0 - How can we add an IP address to that switch so it can be managed by meraki?
1 - tried to factory reset but no go.
Any thoughts on that from the community?
Thank you,
-T
7 Replies 7
RWelch
Getting started: Cisco Catalyst 9300 Management with Meraki Dashboard
Thijo17
I've seen that page before, nothing much it allows me to do. After booting the switch it gets stuck at:
Upoe-plus command is already enabled for switch number:1
And thats it.
This is a brand new switch and it seems to be stuck into meraki mode, and cannot find any info about the mgmt interface being into dhcp to get an IP addr.
Any thoughts on how can we have this switch have an IP configured to reach meraki dashboard?
Thank you,
Thiago
Mloraditch
Do you have one port uplinked to a device that will provide DHCP and internet access?
If no dhcp is available  you can program a static IP by following the C9300 info here: https://documentation.meraki.com/General_Administration/Tools_and_Troubleshooting/Using_the_Cisco_Me...
Thijo17
Should we connect the mgmt port to get an IP OR any other interface?
Thank you,
Thiago
Connect any of the normal interfaces to something that gives it an IP address via DHCP and internet access.  Within a few minutes (sometimes up to 20-30 mins) it'll be setting itself up.
Have you added it to the dashboard etc.?
GreenMan
Meraki Employee All-Star
As cmr has said;   get the switch in touch with the Dashboard, by giving it DHCP (as if it were a PC) and allow outbound access through any upstream firewalls - then do all the swith setup in the Dashboard, once it's successfully active there.   Did you already claim it's Meraki serial number in your Meraki Dashboard?
Do you (did you?) intend to manage this switch via the Meraki Dashboard?
NFL0NR
connect any port to an active connection that allows you to reach the internet
once the switch "checks in" it will give you a green light next to it in the dashboard.
then on the left hand column you can configure the IP of the switch in question.
