Migration from Meraki-managed Mode to CLI-managed Catalyst Switches
ossniper
Hello
I need help as i want to migrate/re-image these Switches which are C9300 UXM and C9300-48P to CLI as i need to implement as AGGR & MGMT SW.
I want to migrate them to Catalyst  so i can manage with Catalyst Center as they are currently being managed by Meraki Dashboard. I have integrate Meraki dashboard with Catalyst Center - DNAC can only see AccessPoint but not the switches..
Best Regards.
2 Replies 2
Migrating to DNA management mode
To migrate your Catalyst switch(es) to DNA management mode, contact Meraki Support. To be migrated, a switch must be online and connected to the Meraki dashboard.
Migration will factory default the switch and all configuration.
When operating in the Meraki-managed mode, Catalyst switches use firmware customized for cloud connectivity.
Once the migration to DNA or CLI managed mode is complete, please be sure to install a supported IOS-XE software version on the switches before deploying them in production networks.
https://documentation.meraki.com/MS/Cloud-Native_IOS_XE/Migration_from_CLI-managed_Catalyst_Switches...
ossniper
Thank you very much for your response.
I have engaged support and will also follow the steps you highlighted so i can work with cisco support once they respond.
