Concrete Mixer A Person?
So our MV cameras think the concrete mixer is a person.
Unfortunately this is contributing to analytics. At what point does the camera decide it's not a person and gives up?Capture.PNG
8 REPLIES 8
Re: Concrete Mixer A Person?
Well...at first glace he does look like a shifty character.
You can try placing an ignore field on that area, even just half of it and that might help the system ignore it.
Nolan Herring | nolanwifi.com
TwitterLinkedIn
yep shifty all right.
whats an ignore field? and how?
https://meraki.cisco.com/blog/2018/08/privacy-where-you-need-it/
To enable this feature, users simply navigate to an individual camera feed and select the ‘Settings’ tab. Then scroll to ‘Privacy Window’ and draw up to 10 boxes within the video feed. These boxes can overlap to cover irregularly shaped areas.
That's not really a solution though is it, as you would want to see if the mixer was moved, taken etc. Privacy window would not be the same as an exclusion.
I guess what I was more after was a way of tagging this as NOT being a person, part of the ML.
I understand what your saying. You might be able to get what you want by simply creating a slice or small privacy window. It would be small enough that you can still basically see what is going on, but large enough that it stops the system from thinking the mixer is a person. Worth a shot me thinks 😃
Good luck !
TwitterLinkedIn
Cheers, good idea, but overall it would be good if somehow you could tag regions that the camera is suspecting as people to help with the ML. Thanks for the idea.
Machine Learning (ML) based Computer Vision (CV) implementations like those in the MV12, MV22, & MV72 get better over time when their models are trained with a larger and more diverse set of real world data. Training does not happen on the camera, this is done at Meraki and then we generate an updated model. The MV cameras' ML CV model is updated when a camera updates its firmware.
The data used to train the camera model is currently only sourced from specific development cameras. In the future we hope to enable customers to submit their own video data to help train the model and make it better. Video clips such as the concrete mixer being falsely detected are high value pieces of training data and would improve our model. For example we have updated the camera model to "train out" detection of specific pieces of gym equipment as people.
Awesome answer, i was hoping future releases would contribute to the ML
