Hi, according to the doumentation for the creation of MQTT broker in https://developer.cisco.com/meraki/api-v1/create-network-mqtt-broker/, we can specify the `caCertificate` field. However, I am not able to find the correct format which the meraki API accepts via the api call. I have tried indicating new lines via \n and \\n, but have had no success with getting the meraki API to accept it. Uploading the same certificate through the Meraki Dashboard works however.
Has anyone had any success with using the API to upload their certificate? Thanks!
