Troubleshooting Phones Provisioning to Ring Central
MerakiMed
in the last week phones stopped being able to be provisioned in Ring Central. They need to get to pp.ringcentral.com:443. Pings to that site from a branch office with Meraki is failing. But pings and
https traffic to other sites works. My first through to troubleshoot tomorrow will be to have a phone
that needs to be provisioned and do a packet capture to see what's going on during that attempted
provisioning.
But it's been some months since I looked at firewall looking. Is it possible to view all conversations allowed through the MX for a time period? I went to Sec & SD WAN/Security Center and selected all dispositions allowed or not. I started to enter the IP address of the provisioning server at RC 199.255.120.237 and the search box suggested I really wanted was remote_ip:199.255.120.237. Ok good enough. I hit enter and the time window is set to an overly generous 2 weeks. But still nothing shows up in the results. Am I searching for these conversations in the wrong place?
Also a snapshot of the conversation is below. It looks like a phone 10.1.61.24 it trying to provision and the RC server is requesting a certificate 1.2TLS. Then the client ends up sending the cert but resending and resending. Any thought what's going on? Invalid certificate?
Thank you.
BrandonS
Just a guess, but try whitelisting the client or toggling AMP and/or IPS/IDS and content filtering off to see if it changes.
10 REPLIES 10
BrandonS
I don't think you can find what you are looking for in the dashboard.
Remember ping does not work everywhere.  I can't ping pp.ringcentral.com either.  They must not allow it.  Having a phone and doing a packet capture should help you isolate the trouble quickly though.
Thanks much. I pasted a screen grab of the pcap of a phone that's trying to provision in the original question.
BrandonS
In Content Filtering I went to the Allow URL and added pp.ringcentral.com. The next time I did a packet capture for that phone it showed registered 200 OK. Good call!
So two add on questions - why could I not see this blocked traffic in Security Center? And I wonder why/how the content filtering changed such as to put the kybosh on my phones provisioning.
Security center only reports ids/ips  and amp.
Content filter is in the event log
MerakiMed
Thanks for pointing that out. So I went and searched in Event Log and..
1) It appears I can't search based on the URI destination.
2) I searched based on the client IP of the phone and nothing shows up there.
3) I went back and searched Security Center once more but by client IP. Nothing.
II may just need to open a ticket to find out why the filtering started on an ostensibly allowed
category and why the traffic denied or allowed is only visible if I run a pcap but not in
event log or security center.
BrandonS
Definitely take this up with support.  Both for not seeing anything in any logs and also why did it block that URL at all?  It seems in a legit category that I assume you were not actively blocking?  Or were you?
Nope - definitely not blocking. I starting thinking blocking based on the retransmits.
Today I found that the phones still aren't provisioning. So I'm not sure why the pcaps changed last night.
I was doing it all remotely and couldn't corroborate what was happening with the phones themselves.
The end of the mystery appears to be in the treatment of traffic nearing pp.ringcentral.com from the external IP of the MX67 which is provided by Comcast. And the issue may involve multiple sites as we use Comcast a lot. I'll ask a troubleshooting specific to this kind of suspected asymmetric traffic problem. I've dealt with a couple in the past but man it's time consuming and frustrating.
BeckerIT
Here's a document link, I found helpful when my company was switching over to RingCentral and ran into similar provisioning issues.
https://support.ringcentral.com/article/9233.html#8.6.3.WhitelistDomains
