- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
AnyConnect for Meraki Client VPN Access?
I heard that AnyConnect compatibility with Meraki MX is coming soon. Does anyone know when it will be available and what needs to be configured on the back end?
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @MerakiMed , reach out to your Meraki AM to discuss the Beta programme. And yes, it would mean running Beta firmware for a period 😕
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi @MerakiMed , believe this is currently on Beta 16.x.
With regards what’s needed at the backend....an MX 😁
I would expect a separate Anyconnect subscription is also required.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thank you. I'd really like to be able to use the AnyConnect. But that would mean putting beta code on the hub devices. Hmm.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
As far as I was told, the closed beta program is literally closed. They have enough networks for tests.
The open beta should be due first quarter 2021.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello All,
It's been a long wait, but finally we are happy to announce that AnyConnect is now available on the Meraki MX as a public beta feature on the MX16.X firmware.
To learn more about AnyConnect on the MX please visit AnyConnect on the MX
Thank you all for your patience!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
This is good news and I'm looking forward to testing. One question however:
In the AnyConnect on MX vs ASA document below - in the Authentication
section - nothing is mentioned about RADIUS nor Active Directory authentication
of users. Is that an oversight? I searched the document for radius and active directory
/AD and not spotting anything. Ideally I'd also like to be able to use Azure 2FA.
Not sure if that's on the horizon.
If I go to the Dashboard and look at Client VPN I see RADIUS. Does that apply to
AnyConnect connections?
https://documentation.meraki.com/AnyConnect_on_ASA_vs_MX?mt-draft=true
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Radius and Active Directory are both available.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@Bsalami Indeed good news!!!
The question now is, how much development should we expect further - like Certificate based only authentication, custom DNS name usage, etc.?
