Source IP and/or VLAN mismatch MX84
Trust
Hello people,
has anyone ever seen these errors and can tell me the reason?
The errors always occur at XX:29:25 and XX:09:25.
- The clients are all configured to DHCP.
- The VLANs are configured Layer 3 on the switches.
- The DHCP server is on the MX84 (relay).
Here is the configuration of the switch ports
Thank you
6 Replies 6
Are you 100% sure that no machine is configured with static IP?
Have you tried to check which ports of the Switches are connected to the source MAC?
Did you set the dhcp server to give out the  switch svi-ip as router/gateway
RaphaelL
1- Does 10.201.10.76 belongs to vlan 340 ? RPF checks are failing. refer to the documentation below
2- The reason why it shows every 30 mins : Every 30 minutes, the top 3 offending clients are logged on dashboard in Network-wide > Event Log. These events are visible in the event log after filtering for Source IP and/or VLAN mismatch.
3- Last resort you can disable the IP spoofing to temporarly allow the trafic.
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/IP_Source_Address_Spoofing_Protecti...
Trust
Hi guys and thanks for your answers.
I have followed these instructions.
https://documentation.meraki.com/MS/Layer_3_Switching/Layer_3_Switch_Example
This is my Transit VLAN
and on the Switch
as an example the VLAN 340 on the switch. As DHCP Relay I have chosen the Transit VLAN
This is my static route on the MX
and the DHCP server on the MX
this is my configuration for the switchport
this way I have created three VLANs on the switch and DHCP servers on the MX.
I am not sure where my mistake is.
I hope I have described everything understandably and you can help me.
Thanks a lot
Trust
any idea?
