Is anyone able to point me to some documentation that is current?
The Azure end is configured we think.
If I go to Security & SD-WAN>Site-Site VPN and set type to Spoke, I can then enter the Non-Meraki VPN peers under the Organization-wide settings.
When I click on Save at the end though it wont allow me to save as there is no hub.
All we are trying to do is create a site-site VPN to allow specific subnets in Azure to access onsite resources behind the MX subject to L3 rules on the MX.
Is there an Idiots Guide to configuring this?
TIA
Solved! Go to Solution.
Update - looks like this may do the tick - will give it a go as soon as I get the chance and report back.
@Dunky : Did you check this guide
Yes, doesn't work.
Give the error I mentioned when try to same it - no Hubs.
Set your device to hub.
Security & SD-WAN>Site-Site VPN and set type to Hub,
Thanks ww - will give that a whirl
