SDSL and Mx84
Ludo
SDSL and Mx84
We will switch from an ADSL connection to an SDSL connection. What needs to be changed on the firewall side (actually configured for the ADSL connection) ?
2 REPLIES 2
mmmmmmark
Couple of things to think about.
1. Do you have a static IP and is it going to change? If so then you'll need to go into the local management of the MX and change it there (navigate to http://mx.meraki.com/ in a browser)
2. If you have already set traffic shaping, you'll probably have to change it as the SDSL should have a higher upload and possibly download too, in the Meraki portal go to Security appliance --> Configure --> Traffic Shaping
Not sure about the ramifications of any changes in PPPoE but the provider should be able to help you out with that.
Also, if you have any external DNS pointing to your existing IP and it's going to change, you'll have to update the existing DNS.
I'm sure others will chime in with more stuff but that's what I can think up.
Thanks,
Mark
