Meraki MX75 Random reboots
SeanW
Just an open topic to owners of the MX75 router. I noticed that my MX75 would randomly stop passing traffic and at times would randomly reboot on its own. There is no real constant with this issue as its happened over multiple firmware releases, cable replacements, and UPSs updates. I was on the phone with support today about this issue and he stated there have been reports of MS75 owners having random issues the unit have two or three causes they are looking into. I'm ok with this (to a point), but I hadn't seen any buzz on the forums about this so I am just opening this topic to see if anyone else is having this issue as well, and if it was fixed what fixed it for you?
57 Replies 57
BlakeRichardson
Hmmm I don't recall seeing this being a reoccurring issue. Have you tried an RMA to see if that resolves the problem for you. Usually with large scale issues a replacement program is launched and affected devices replaced.
SeanW
My Eng wants to wait and see before setting up the RMA.
RWelch
I’d have a tough time with the wait and see approach.  If there is an impact to business the RMA would be the route I’d lean on/toward.  Just my 2 cents.
Brash
Not sure about the not passing traffic.
There is however  a hardware defect that impacts some MX75's causing it to crash and reboot due to a kernel panic.
Support should be able to confirm whether that's occurring or not.
For reference: Re: I'm seeing some very strange and unlikely high defect rates with MX75 (... - The Meraki Communit...
I had an MX75 replaced as the power socket was dodgy and touching the connector would reboot it.  The replacement was apparently one of the dodgy ones as it rebooted a few times, especially when both PoE ports were used.  However upgrading to MX19 fixed it and it has been stable since.
SeanW
Funny enough 19.1.5 was my less stable FW.
TyShawn
Hey @Brash,
What was the final result of your issue, did the replacement fix your issue or are you still fighting the good fight?
Brash
Support confirmed the issue on 2 MX75's and sent RMA's. Aside from the replacement device, they also came with smaller power transformers.
I haven't had any further random reboots on them since then.
I had one of those smaller (more powerful) transformers with the RMA replacement I had for a loose power connection.  Are your new PSUs more powerful?
Brash
Hmmm can't recall. I just checked they had the same voltage and polarity and swapped them in along with the replacement MX
The replacement one I received was an 120W FSP power supply.
TyShawn
My PSU looks to be the same for both units, but give me a couple hours and I can post some pics of both.
Inderdeep
I would suggest reach out to meraki support first and then go with RMA if required @SeanW
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
I *think* I have had my MX75 reboot once.  It's hard to tell apart from jut a short Internet disruption.
JamesT91
Yes - we have seen lots of MX75 devices plagued by 'panic reboots' which can have several underlying causes according to support. Get it RMA'd.
SeanW
After rolling back to 18.211.4 things have stabilized again. Next steps is to try 19.1.4 again and see if the issues return.
Guess it would help if I gave some additional information on the setup a well.
Topology ISP 1 (1G) - ISP 2 (1G) --> MX75 --> L3 VLAN --> Unifi 10GB switch L3 VLAN --> Multiple VLANs over multiple ports --> MR 44 1 - MR 44 2 --> Clients wired - Wireless.
SeanW
Small update on this issue. FW 18.211.4 was stable and did not have the reboot issue. I've updated the MX to 19.1.6 and so far the issue hasn't returned.
TyShawn
Christmas Eve update: My MX75 had another kernel panic event yesterday with 19.1.6, Meraki support is sending out a replacement unit.
TyShawn
Update: The replacement unit is installed and updated to 19.1.6, now we wait and see if the issue returns.
TyShawn
Welp that was the longest couple hours in history :).
OLD PSU
New PSU
I think my replacement PSU was the one you had...  The old one I had was smaller and I think the make started with Chang...  I can't tell if your new is that, of a third variant?
This is the replacement I got, I think it is your old one as it doesn't have the EAC mark on it:
Actually mine doesn't even have a UKCA mark... 🤔
TyShawn
Maybe a pre-production model...?
TyShawn
So the PN is the same over all three pictures, and you're right EAC is different.
JGTS
Hi all,
Also experiencing this at one site, and have RMA'd 3 times now. The most recent replacement lasted 32 days online over the Christmas break but then rebooted today randomly again. I've reopened the ticket again.
Support had previously advised that engineering were aware of the issue but no solution available yet. The client is ready to pull the plug entirely.
Has anyone had some success on this yet?
Thanks.
TyShawn
So far things are holding steady for me but still soaking.
JGTS
Our last replacement took a month to fail again, just when we thought we were home free. 😓
We're in Australia, where RMA stock is supplied separately from new stock. I.e., if I order a fresh MX75 it comes out of Ontario and takes a week to arrive, but if I RMA a device, it comes locally the next day. If it is indeed a PSU problem, I wonder if the 'new' stock coming out of Ontario has the fixed PSU.
I had one restart yesterday morning that (as far as I can tell) has been stable for months, but initially crashed a few times.  Unfortunately the logs only show ethernet carrier changes for all ports followed by X dropped events...  Therefore unless it impacts you, it's difficult to trace when it happens!
dhub
Same issue here, I'm running MX 18.211.4.  Support suggested I factory reset, I did that on January 1 - the MX75 has crashed 3 times since factory reset.  Event log shows Ethernet port carrier change.  I'm upgrading to MX 18.211.5 tonight.
Support offered to RMA if it crashes again but I'm not too optimistic reading through all of these responses.
JGTS
I'm now onto my 4th RMA for the same site. The customer is ready to walk away.
What kind of configuration and ports in use do they have?
jOMeraki2
This issue happened to me with the same model, and the solution was that they processed an RMA for me.
GiacomoS
Hey folks,
Apologies for the radio silence on this issue here. We have been seeing this issue with a few customers and have been hard at work with all your support (thank you everyone who troubleshot with us!) to get to the root cause of it.
This investigation is being treated as a priority and we have dedicated all suitable resources to help resolve it; for units identified hitting this issue we have been leveraging RMAs as the quickest path to recovery, but we appreciate that this is not an ideal step in all circumstances and deployments.
For the time being, I'd continue to encourage everyone to raise a case (if you haven't already), make sure you troubleshoot with Support and discuss the best option based on your individual circumstances (RMA or wait for a software fix if possible).
Thank you for all your patience here, we completely understand how impactful this is.
Giac
Please keep in mind that what I post here is my personal knowledge and opinion. Don't take anything I say for the Holy Grail, but try and see!
Appreciate who helps and be respectful of every opinion and every solution offered.
Share the love, especially the Meraki one!
CedricMX
Are you 100% sure that the MX75s returned as replacements will not restart randomly?
I saw on the Meraki community that some users had obtained replacement MX75s that were also affected by this same problem.
Can you send 100% functional MX75s? Is it possible to do the stress tests at Cisco rather than asking your customers to do them?
We are Meraki customers and have no time to lose.
JGTS
Thank you for replying. I'm on my 4th replacement at one site, and have two more exhibiting the same behavior. Is there a way we can get an RMA from a different batch?
As you can imagine, it's extremely disruptive to the client and puts a lot of stress on our technical team to respond each time. As a business, we're also having to cover the labor costs each time it needs troubleshooting and replacement, as well as wearing the reputational damage for continuing to stand behind the product.
Is there anything else more tangible that you can provide around an ETA, so that we can pass this on to the client? I'm sure everyone's working hard on a solution, but at this late stage, we need to communicate more than it is still a priority.
Thank you.
CedricMX
Did the Meraki RMA solve your reboot problem?
Has a replacement product ever been affected by the reboot problem?
JGTS
Yes, I've had 3 faulty replacements and currently onto a 4th now (stable for four days so far). The 3rd replacement lasted 31 days before it started rebooting randomly again.
CedricMX
ohhh !
I understand why you are talking about time and costs about this issue with MX75.
If spare products are not usable, has Meraki proposed another solution? For example, make somes tests on replacement products before sending them to customers or offering another mx model in order to compensate for customers extra cost due to this issue ?
JGTS
Unfortunately, not yet. I've asked the question, but haven't been given a solution apart from continuously RMAing at the moment.
I do have a number of other MX75s in the field that aren't affected by the same issue though, so it's very much a game of roulette at the moment.
JGTS
Is there any update on this? We've now got another client confirmed with the same issue, so again are having to deploy resources to RMA and replace.
Thanks.
dhub
FWIW, I updated to 18.211.5 on 1/24/25 and haven't had a reboot since.
Let's hope the latest release has finally fixed it 🤞
TyShawn
For me an RMA and moving to 19.X has been my fix so far.
GrumpyBug
I've got two units at two sites that would simply stop passing traffic- all Ethernet Link indicators go dark, and the unit status light goes amber.  No reboot, just mute.  No kernel panic in the logs.  The first unit started this behavior back in January, and it was only staying online (up ) for anywhere from 4 to 12 hours.  Meraki support RMA'ed it, and the replacement has been running solid since.
The second unit (at a different site) locked up - (went mute) this morning. A cold reboot (power) restored services.  If it happens again, I'll get Meraki to RMA this one also.
Firmware version 18.211.5
I've been unable to find any posts that show Meraki has acknowledged this as a problem.
dhub
Sounds like RMA is your best bet.  A few posts up, GiacomoS acknowledged Meraki is aware and investigating.  It does seem to be taking a long while to find a solution.
Frank-NL
I can confirm we had a few MX75 cold reboot cases. Now replaced these for MX85 (which are starting to show reboots as well 🙃)
TyShawn
Did you open a support case and have them pull the logs? You will want to make sure its the same symptoms.
Sprocket
There are quite a few known stability issues with the MX75 and firmware 18.211.x if you read the release notes. Like "unexpected reboots" etc.
GiacomoS
Hey Community!
Thank you again for all your patience and support with this issue. I know it has been a major cause of headaches for many of you, and with all your help in troubleshooting I'm happy to share that the fix for this has arrived in firmware MX 19.1.8, the current stable release candidate.
A few recommendations before you dive head first:
- If you are already in touch with our Support and Escalations team, please work with your aligned engineer to discuss the upgrade.
- Roll out the upgrade on one location and test all of your applications and services before distributing it to the whole organization.
- If you have a big organization, plan the upgrade in batches, not all in one go.
- If possible, have someone on site that can assist with support data bundle gathering, reboots and factory reset.
- Have a rollback plan in case something doesn't work, keeping in mind that if the device goes offline, it may not receive the configuration to revert the firmware upgrade.
As always, Support is here to help. Give us a ring if anything doesn't work as expected.
Again, thank you for working with us through this!
Giac
kenbartlingLEAP
Just browsing
I have one client with the MX75 that is doing as described. Support FINALLY sent an RMA, then updated to 19.1.8 and still having the lockup issue. I have sent the engineer an email without any response as of today. Client is extremely frustrated with Meraki support.
GiacomoS
Hey @kenbartlingLEAP ,
Sorry to hear, let me see if I can help!
Can you drop me a direct message with the case number please? I'll follow up with you separately.
Could you also elaborate on what you mean with "lockup" please? The circumstances we are talking about here are not of the MX freezing, but rather of it rebooting by itself.
Many thanks!
Giac
kenbartlingLEAP
Just browsing
I have a reply in from the engineer. I will update you if there's no resolution.
TK-ECH
It seems that firmware that can be used to address equipment freezes is now available.(MX 19.1.8.99)
You can apply it by contacting support.
I had it applied to my MX75, which was periodically hanging up, and am currently monitoring the situation.
TyShawn
So far 9.1.8 is working for me. To give this a true test I have a few weeks before I can say If this unit is working for me.
GiacomoS
Hello folks,
Thank you @TK-ECH for sharing. Just a couple of clarifications on my side:
  • If possible, please make sure you have someone physically present with the impacted device and call into Support. There's a few physical observations and tests that need to be performed to ensure the issue being encountered is the one we are addressing with the interim firmware and not a different one.
  • The firmware mentioned above is an interim patch. We have done extensive testing, but it is not marked as a stable or release candidate firmware. Make sure you accommodate enough time in a maintenance window to test your environment if we agree to proceed with the upgrade route.
Please, keep working with our Support team to identify the best path forward based on your circumstances. 🙏
Thank you so much everyone!
Giac
