Meraki MX75 Random reboots
SeanW
Just an open topic to owners of the MX75 router. I noticed that my MX75 would randomly stop passing traffic and at times would randomly reboot on its own. There is no real constant with this issue as its happened over multiple firmware releases, cable replacements, and UPSs updates. I was on the phone with support today about this issue and he stated there have been reports of MS75 owners having random issues the unit have two or three causes they are looking into. I'm ok with this (to a point), but I hadn't seen any buzz on the forums about this so I am just opening this topic to see if anyone else is having this issue as well, and if it was fixed what fixed it for you?
30 Replies 30
BlakeRichardson
Hmmm I don't recall seeing this being a reoccurring issue. Have you tried an RMA to see if that resolves the problem for you. Usually with large scale issues a replacement program is launched and affected devices replaced.
SeanW
My Eng wants to wait and see before setting up the RMA.
RWelch
I’d have a tough time with the wait and see approach.  If there is an impact to business the RMA would be the route I’d lean on/toward.  Just my 2 cents.
Brash
Not sure about the not passing traffic.
There is however  a hardware defect that impacts some MX75's causing it to crash and reboot due to a kernel panic.
Support should be able to confirm whether that's occurring or not.
For reference: Re: I'm seeing some very strange and unlikely high defect rates with MX75 (... - The Meraki Communit...
I had an MX75 replaced as the power socket was dodgy and touching the connector would reboot it.  The replacement was apparently one of the dodgy ones as it rebooted a few times, especially when both PoE ports were used.  However upgrading to MX19 fixed it and it has been stable since.
SeanW
Funny enough 19.1.5 was my less stable FW.
TyShawn
Hey @Brash,
What was the final result of your issue, did the replacement fix your issue or are you still fighting the good fight?
Brash
Support confirmed the issue on 2 MX75's and sent RMA's. Aside from the replacement device, they also came with smaller power transformers.
I haven't had any further random reboots on them since then.
I had one of those smaller (more powerful) transformers with the RMA replacement I had for a loose power connection.  Are your new PSUs more powerful?
Brash
Hmmm can't recall. I just checked they had the same voltage and polarity and swapped them in along with the replacement MX
The replacement one I received was an 120W FSP power supply.
TyShawn
My PSU looks to be the same for both units, but give me a couple hours and I can post some pics of both.
Inderdeep
I would suggest reach out to meraki support first and then go with RMA if required @SeanW
Regards/Inder
www.thenetworkdna.com
I *think* I have had my MX75 reboot once.  It's hard to tell apart from jut a short Internet disruption.
jimmyt234
Yes - we have seen lots of MX75 devices plagued by 'panic reboots' which can have several underlying causes according to support. Get it RMA'd.
SeanW
After rolling back to 18.211.4 things have stabilized again. Next steps is to try 19.1.4 again and see if the issues return.
Guess it would help if I gave some additional information on the setup a well.
Topology ISP 1 (1G) - ISP 2 (1G) --> MX75 --> L3 VLAN --> Unifi 10GB switch L3 VLAN --> Multiple VLANs over multiple ports --> MR 44 1 - MR 44 2 --> Clients wired - Wireless.
SeanW
Small update on this issue. FW 18.211.4 was stable and did not have the reboot issue. I've updated the MX to 19.1.6 and so far the issue hasn't returned.
TyShawn
Christmas Eve update: My MX75 had another kernel panic event yesterday with 19.1.6, Meraki support is sending out a replacement unit.
TyShawn
Update: The replacement unit is installed and updated to 19.1.6, now we wait and see if the issue returns.
TyShawn
Welp that was the longest couple hours in history :).
OLD PSU
New PSU
I think my replacement PSU was the one you had...  The old one I had was smaller and I think the make started with Chang...  I can't tell if your new is that, of a third variant?
This is the replacement I got, I think it is your old one as it doesn't have the EAC mark on it:
Actually mine doesn't even have a UKCA mark... 🤔
TyShawn
Maybe a pre-production model...?
TyShawn
So the PN is the same over all three pictures, and you're right EAC is different.
JGTS
Hi all,
Also experiencing this at one site, and have RMA'd 3 times now. The most recent replacement lasted 32 days online over the Christmas break but then rebooted today randomly again. I've reopened the ticket again.
Support had previously advised that engineering were aware of the issue but no solution available yet. The client is ready to pull the plug entirely.
Has anyone had some success on this yet?
Thanks.
TyShawn
So far things are holding steady for me but still soaking.
JGTS
Our last replacement took a month to fail again, just when we thought we were home free. 😓
We're in Australia, where RMA stock is supplied separately from new stock. I.e., if I order a fresh MX75 it comes out of Ontario and takes a week to arrive, but if I RMA a device, it comes locally the next day. If it is indeed a PSU problem, I wonder if the 'new' stock coming out of Ontario has the fixed PSU.
I had one restart yesterday morning that (as far as I can tell) has been stable for months, but initially crashed a few times.  Unfortunately the logs only show ethernet carrier changes for all ports followed by X dropped events...  Therefore unless it impacts you, it's difficult to trace when it happens!
