MX68cw with LTE as primary
I´ve recieved a question regarding a router for 4G and Wifi for 2 sites where there are no WAN connectivity with fiber. I though of using the MX68cw to use as router for this use case. The MX68cw has LTE as failover and I wanted to use it as primary connection. Is it possible to use it like I want or am I just wrong?
We discussed configuring the MX68cw at a site were there is a Wan connection and then ship it to the new sites.
Any feedback is welcome.
BR
Andreas
Accepted Solutions
Re: MX68cw with LTE as primary
Hi
Yes we run a site with 4G as primary so i'm sure it can be with LTE as well. I just cropped out other information.
Our model is MX68CW-WW
8 REPLIES 8
Hi
Hi
This is the best news this week!
Have a nice weekend.
BR
Andreas
When you set it up, did you then use a WAN connection the first time or did you set it up directly with 4G?
The set up is process is important since there is no WAN connection today at all.
This unit is supposed to be used as the first link out for the new sites
Yes we first had to setup the device on another connection so that we could enter our unique APN name and then switch over to 4G
OK,
So this could be done anywhere, just need a WAN connection, and then ship it to the intended sites. Correct?
BR
Andreas
Yes, So we did the setup in our office. Rebooted made sure 4G is working and then shipped it to site.
What you could test is the following when you have the device. Insert the sim into the router and see if it wil connect with default settings. Our mobile provider in SA is configured in such a way if you dont specify the APN name it defaults you to the internet apn. Something to have a look with your mobile network
OK, I will try that. Thanks.
BR
Andreas
Paragraph taken from the Meraki documentation:
"Please note that upon first-time bootup and connection to the Meraki Cloud, an ethernet WAN connection must be used to download the initial configuration and get the device online the first time."
https://documentation.meraki.com/MX/Cellular/3G%2F%2F4G_Cellular_Failover_with_USB_Modems
Darren O'Connor | uccert.co.uk
