I can't see CPU usage from Summary Report. It's showing not enough data to display. Current version: MX 14.53
What is the issue?
It has never showed any data. Maybe it's something they want to implement in the future.
Yep, it’s always been the case, on MX14, MX15 and MX16 firmware - it’s never shown any data in any version I’ve seen. In all honesty I don’t know why Meraki keep it in the summary report.
Appears ok in my Summary Report:
MX67's and MX84's running 15.42.1
Possbily something you need to ask support to enable. As mentioned its always been there and never worked.
@Dunky not that one (whole organisation), pick an individual network with an MX in it and there is a chart on the left hand column at the bottom below device utilisation that never has data...
