Lost PoE on Z4 after upgrade to 18.211.5
StevePF
We lost PoE on a few Z4 after upgrade to 18.211.5.
Wondering if anyone had this issue?
Logging locally, the PoE option on port 5 is on.
8 Replies 8
Mloraditch
It's not in the known issues list last I saw but this is a bug per support. We had to roll back to 18.211.3. I'd open a case so you get attached to the bug and get notification when it's fixed and increase its visibility.
Inderdeep
This is definitely a bug, Do check with support @StevePF
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
webx123
Working with OP. The bug ID is MX-34938. We can read it in 19.1.7 change log but no reference to this bug on the newest 18.211.5.1 stable change log.
chakshu
This is a known bug on 18.211.4/.5, rolling back to 18.211.3 should fix the issue.
Do rate helpful posts by leaving your kudos/mark it as solved.
DonkeyDOC
I had a ticket with Support, but they said nothing wrong with it.
I just tested in lab and I can repeat the issue.
with a power injector on port 5, my camera and port 5 both work.
Mloraditch
Did you mention the bug id listed above? You may need to escalate. Support engineers are not perfect.
BobR2
Mine was fixed in 18.211.6.
AlexL1
StevePFMloraditch, and DonkeyDOC,
I hope your day is going well.
We would like to let you know that this was resolved in MX 18.211.6+ and 19.1.8.
The workaround was to downgrade to MX18.211.3.
If you have any questions, please let us know.
