Azure S2S VPN
charles07
Azure S2S VPN
Does Meraki MX supports Azure VPN with Basic SKU VPN Gateway.
Azure VPN Gateway configuration has an option to select SKU - https://docs.microsoft.com/en-us/azure/vpn-gateway/vpn-gateway-about-vpngateways
From my observation if Basic is selected, Meraki would not form S2S tunnel.
If any SKU above Basic is selected, Meraki MX forms S2S tunnel successfully.
Any idea why Meraki MX is not able to form S2S tunnel with Azure for Basic SKU.
Azure VPN SKU mentioned here - https://docs.microsoft.com/en-us/azure/vpn-gateway/vpn-gateway-about-vpngateways under "Gateway SKUs by tunnel, connection, and throughput"
charles07
After hours of troubleshooting we identified the issue.
Meraki MX does not form VPN with Azure Basic Gateway SKU
Azure VPN gateway SKU should be VPNGW1 or higher
Our Azure SKU was Basic. Somehow Meraki was not forming tunnel with it.
https://docs.microsoft.com/en-us/azure/vpn-gateway/vpn-gateway-about-vpn-gateway-settings
I think it should work.  Just make sure you configure it as a policy-based VPN, and note that you can only have one policy-based VPN.
Another option (which we have used lots) is to deploy an Ubuntu machine running StrongSwan and terminate the VPN on that.
https://www.ifm.net.nz/cookbooks/meraki-vpn-to-azure.html
charles07
JimmyM
Hello.
Just to mention that on my side I have a lot of customers with a dr site in Azure and all of them are with the Basic SKU. I haven't had a problem with the MX68, 84, 85 and 100.
Boyan1
Confirming that basic SKU does work but Microsoft is decommissioning those SKUs in 2025 so moot point today
