Group Policy Firewall Rules - Adding multiple ports on the same rule
SimonReach
Been looking at locking our network down even more than it is and been using the Site to Site VPN firewall rules and they seem to be really nice to work with and you've got the ability to add multiple ports for a single rule e.g. Port 80,443, etc.
With the Group Policy Layer 3 Firewall rules, you seem to either have a choice of Any, or doing a continuous group of ports e.g. 123-127, or adding a single port in.
Is there no way to add multiple ports with commas to the Group Policies, like there is on the Site To Site VPN Firewall?
GIdenJoe
The design issue is that group policies are designed to work with both access points and security appliances.  The access points don't have support for comma based port grouping.  This means the functionality cannot be given to a group policy.
That's an original design decision that can bite you in the behind 😉
Unfortunately not, you can only do it with a range.
SimonReach
Thank you.
GIdenJoe
SimonReach
Thank you.
