- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
iOS/iPadOS Return to Service
Hello! I see that SM supports the new iOS/iPadOS 17 feature "Return to Service", which allows you to wipe a device but send a WiFi profile to have it set itself up after the wipe. You can find this feature on the new SM interface when you check the box of a device and then under command, erase devices. I've tried it a few times but it only unenrolls the device and wont wipe it. I don't see any documentation on Meraki's site, only on Apple's site. I have a case in but has anyone else tried this feature?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Can you raise a case for this please? And Direct Message me the case number when done?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have yet to try this but I will try and test this myself with a device today if I can.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Tried this feature several times now, but it always just tells "Management profile removed" on the dashboard.
On the device itself seems like nothing has changed.
I can still find all apps and the management profile under the device settings.
I didn't file a case yet
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Engineering are working on this. Stay tuned.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi, is there any update on this? We would like to use it too.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Meraki have a case open with Apple on this currently, so no update as of yet. As soon as we have an update, we'll update this thread
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Meraki SM and Apple are still working together on this, but no ETA for resolution at this time.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Okay, thank you for the update. I was eager to try this in preparation for our summer iPad resets, so I wanted to check in and see if anyone had heard anything.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Any word a fix? It would be really great for us school districts to have this option in the summer.
With the new 17.5 I noticed a new error when trying to do a "return to service" erase.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello, has this issue been resolved?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Any further update?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
No, I have not yet heard any communication around this. I have been patiently waiting. We have 1500 iPads to reset this summer and this would really make things go a lot faster if they had a solution or fixed whatever the issue is with the re turn to service option.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
From what I can tell, it seems like a bug or maybe something missing in the Meraki end of things. Haven’t seen any official fix yet, but I’m following that Apple doc too.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I tried again and am still running into the same issue, I assume there is no fix yet.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Happy 12+ month anniversary past the first post 🎉
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I went to an Apple panel yesterday at the CITE conference where they demostrated Return to Service. It was a smooth demostration of a cool feature. Apple used Mosyle as their MDM. When I talked to a couple Apple people after the demostration and mentioned my MDM doesn't support this feature yet, they asked me what MDM I used. When I said Meraki, they made a face and suggested I "get a real MDM."
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Have you heard any update on this yet?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The amount of time this feature would save if it worked properly would be substantial.
As of april 2024 "Meraki SM and Apple are still working together on this, but no ETA for resolution at this time."
