Get device location via API
Stavros
Hello all,
Has anyone found a way to get location coordinates for supervised devices instead of descriptive text?
Regards
4 REPLIES 4
Inderdeep
Re: Get device location via API
Hi @Stavros : All Meraki wireless products offer out–of–the–box, easy to use location features as part of  Cisco’s location analytics technology, Connected Mobile Experiences (CMX). Have a look on below link to get the more on the X,Y coordinates and latitude and longitude values
https://meraki.cisco.com/blog/tag/location-2/
Regards
Inderdeep Singh
www.thenetworkdna.com
Regards
Inderdeep Singh
Stavros
Hello @Inderdeep
Thank you for the reply. I am actually talking on SM managed devices (eg. ipads) and how to utilize API to grab device (last known) location. It seems that (to my knowledge at least) in both v0 and v1 there is no such call.
Best,
Stavros
Inderdeep
Hi @Stavros Did you check this as i think by default it is there on the below request type.
Let me know if it helps
Regards
Inderdeep Singh
Regards
Inderdeep Singh
Shany
@Inderdeep
Even if query the "fields=location" using API, the coordinates are not displayed.
Only addresses information that can be located are displayed.
The address must be checked from the coordinate value, but I am wondering if there is a way to solve the problem of showing only the address.
