You can filter the view to only include the WAN 1 & 2 ports
(uplink:"WAN 1" OR uplink:"WAN 2")
Ryan / Meraki SE
If you found this post helpful, please give it Kudos. If my answer solved your problem click Accept as Solution so others can benefit from it.
