NEW Meraki MDM Deployment - iTunes and iCloud Restorations Required
Good evening all!
My name is Chris and I am an IT Manager here in Columbia, SC. We have Meraki MDM implemented on a few phones and are looking to MDM all of our corporate phones. We are in the process of migrating carriers so we need to touch every phone in the company which creates a great opportunity to MDM the non-MDM company phones that we have currently, and/or deploy the new phones with MDM. My challenge seems to be setting up MDM fully while also restoring from an end-users iTunes backup. When restoring from an iTunes backup, the SM app has to be installed manually and the phone does not become fully supervised and the Meraki profile is removable. We want the transition to be as smooth as possible. Do you have any recommendations as to how we can achieve a restore that will maintain full supervision and hardening of the phones? If there is already a thread on this, I do apologize. I looked and did not see anything specific to this topic. Thank you all in advance for your insight.
Best Regards,
Chris Murdaugh
Accepted Solutions
Re: NEW Meraki MDM Deployment - iTunes and iCloud Restorations Required
I believe where we landed on this was that if you are trying to bring a device from an unsupervised to a supervised state, restore from backup will not work at initial setup (either from itunes or icloud). Our recommended method would be to have your users sync any app data in icloud, and then login and re-download that app data from icloud once setup is complete (this can't be done in the "restore from backup" step in initial setup). I would probably suggest skipping that step (you can take it out of the setup process by selecting it in "skip steps" when applying DEP settings).
Note - if you were *just* enrolling the device in DEP and not supervising it, it sounds like restore from backup would work at initial setup.
With regard to the wifi profile disappearing once it's enrolled - I believe what's happening is once you have configured the Meraki Management Profile (SM), any previous profiles will be removed. To configure a wifi profile with Systems Manager, you can set one up in the Systems Manager>Settings page. Here's more on that - https://documentation.meraki.com/SM/Profiles_and_Settings/Configuration_Settings
I'm not sure why you're not able to access user account settings - do you mean the user is no longer logged in (to icloud?) or that logging in to icloud is blocked? There is a restriction you can set to block this - in SM it is under Settings>Restrictions>Allow Modifying Account Settings. If this was unchecked, that would block a user from signing in to icloud.
Hope this helps!
68 REPLIES 68
My experience is that to remain supervised through a restore, the device has to be in the Apple DEP program.
I don't think you can do this.
I really hope this isn't the case. I can see them coming with pitch forks and torches.
And then if you're in the Apple VPP, you can purchase apps and assign them to the device once the device gets an internet connection.
I just finished setting up some iPads that are in the DEP and VPP so I power up the iPad, tell it what language and country i'm in, hook it up to wifi and the Meraki MDM does the rest, installing apps (you need to include the Meraki Systems Manager app in the VPP for this to work), arranging the apps on the screen, etc.
Thanks,
Mark
We are in VPP and DEP. If we just wanted to deploy new phones without restoring from a backup, we would be all set. The problem seems to be when restoring from a backup of a device that is not in MDM. The goal is to retain our employees iPhone data on the phone to make the transition smoother.
I don't believe you will be able to restore data from a personal account into a corporate controlled device - which uses a different account.  You are talking about phones being transitioned from being "personally" configured with a personal iTunes account to being corporate configured on a corporate iTunes account.
If you could just transfer things between accounts like this iTunes revenue would be in trouble.
So, if you use Apple Configurator and you prompt enrollment that way and the user goes to restore from a backup, enrollment will be totally wiped and never hit the phone. The thing about DEP which is great is that supervision and the MDM profile become mandatory! Once your devices are in the DEP portal and assigned to Meraki go to the DEP section (in Meraki) and assign prestage settings. Here are mine (notice that supervision and the MDM profile are mandatory).
*Note: You must assign settings before the device starts setup - if no, the settings will not be recived.
The user will navigate through prestage enrollment and the user will be prompted to restore from iCloud or an iTunes backup, allow them to do this... after that is completed they will be prompted with a "Remote Managment" screen and they will be asked to imput their AD credeintials (if you set that up) which will supervise, install the MDM profile, and install the Meraki app. *As @PhilipDAth you need to have VPP setup and the Meraki app scoped to the devices with auto install to have it pop down as managed.
Hope this helps,
Jared
If you are ever deploying Apple devices and are using an MDM, make sure you get VPP and DEP. They are great products and are FREE!
Unless you have a Mac so you can run the Apple Configurator - the DEP program is horrible for small to medium sized business to deal with. It is fine for large volume purchases of Apple hardware.
On the whole, I recommend small to medium business use Android devices.  Cheaper.  More apps.  Easier to manage.  More options.  Usually no vendor lock in.
@PhilipDAth I agree in some cases. But, most of the users I deploy to are used to iOS and it is a reliable and good choice. With the new Apple Configurator you can enroll devices into DEP not even bought from Apple (with the 30 day period that they can be unenrolled by the user). Usually you don't even have to touch DEP if you just have it auto-assign to your server.
You can if you have an Apple Mac - otherwise you can't really. A major limitation to use DEP.
@PhilipDAth I'm confused about your concerns with DEP. We use it with Mac's and iOS devices without ever having them touch Apple Configurator. DEP is a bit of a pain to get the initial enrollment set up with Apple, but then it's very easy to use and implement through Meraki SM.
MRCUR | CMNO #12
@MRCUR I spent about three weeks trying to get an Apple Customer Number from Apple for one customer.  I'm never doing that again.  Apple is just too painful to deal with directly.
For the vast majority of other customers, who don't buy direct from Apple, you have to rely on your Apple reseller to get you DEP enrolled.  I've found about 50% of them say "What is DEP", and they are not willing or unable to process the DEP enrolment.
About 30% of them know about DEP, but you can spend 2 or 3 weeks waiting while they try and contact the right person inside of their companies to process them.
About 10% of them are completely DEP switched on, and can just do it.
It has gotten so bad that I now tag it out of jobs.  I tell the customer if they want to use DEP and Apple devices they have to take responsibility for arranging the DEP portion.
It has been a horrible horrible experience getting Apple devices DEP enrolled - a lot of different times.
@PhilipDAth When I was setting of DEP I spoke directly with the buisness team at my Apple store. While the buisness number is great for support, the local team at your local Apple is the best.
It only took them 3 days to get us all setup with VPP and DEP. I just feel there is a lot of mis-conceptions about Apple in the enterprise.
Maybe Apple are better to deal with in your country.  Like I said, I have had so many bad experiences I don't want to do another DEP configuration again.
Unfortunately you cannot "restore from backup" using itunes/icloud when moving the device from one state to another (unsupervised to supervised, or outside of DEP to enrolled in DEP). If the device was not previously supervised or enrolled in DEP, the backup will reflect a different device state and cannot be used to "restore" on a new device state 😞
One thing we've seen folks do is ask users to backup any data they'd like to keep in icloud on a per-app basis. Upon setup, DEP settings will be applied to skip the "restore from" options - these cannot be used on initial setup.
Once setup is complete, users can then log in to icloud to re-download this data on a per-app basis. This is per-app data and not saved in a way that conflicts with the new device state.
The biggest downfall I've seen from this method is losing data from those apps that cannot be backed up on a per-app basis in icloud - namely messages/texts. If it's critical that users keep their text history, there are other solutions for this! I've heard people like Touch Copy, for example.
@Melissa It is 100% possible to take an unsupervised backup and install it on a DEP device. I have taken 20+ unsupervised devices and switched them over to DEP with no loss in data. DEP forces the user to install the MDM profile after the backup is installed. Personally, Apple has never made it clear on how to do this and it makes system admins find it themselves.
Maybe I misread this - I thought in this case we were moving from an unsupervised enrolled device (not in DEP) to a supervised device in DEP. Is that not right?
I believe that is there goal. That is possible, if the device is in DEP and unsupervised backup can be used. This method does work in Apple Configurator.
@jared_f Are you saying you've been able to use Apple Configurator to take an unsupervised, un-enrolled (in DEP) device and enroll it into SM and DEP with supervised DEP settings applied, while allowing "restore from backup" in the initial setup?
The main hurdle would be moving from unsupervised to supervised while allowing "restore from backup".
Please let me know what your experience has been!!
I took some of my unsupervised devices that were not in my DEP and added them to DEP with the new Apple Configurator. Any DEP device can be restored from an unsupervised or supervised backup (iCloud or iTunes) because DEP pushes the enrollment payload after the restore wizard.
This cannot be done if you are just using Apple Configurator to add supervision. Device must be enrolled in DEP and have prestage enrollment setup in Meraki in order to complete this.
This matches what I've seen with iOS @jared_f. As long as you have the device entered in DEP and have settings assigned through Dashboard, DEP enrollment will properly happen even after you restore from a backup that was not previously DEP/supervised.
I will note that this does NOT work for Mac's. If you have a Mac that's enrolled in DEP and then you restore an image of that Mac to another Mac that has DEP settings assigned, the second Mac will not be enrolled in DEP.
MRCUR | CMNO #12
Right, so in this case, if @CMurdaugh would like to supervise these devices, restore from backup cannot be used. If it's not the goal to supervise them - just to add them to DEP...the Apple Configurator + restore from backup method should work!
Depending on what method they use, if it involves touching the device, take the time to setup DEP. If the phone ever gets wiped, it won't require enrollment to happen again.
Hi all,
i've read the comments and i'm in the same boat as the OP (i think).
I need to supervise/enroll 150 devices that are already in service. None of them are in DEP yet, but that framework is all setup and ready to go (along with Apple Conf 2.6.2).
Still unsure about best practice for doing this, so continued replies would be appreciated. 🙂
@Jacko Do you need to restore the existing data or not? Either way, you need to get the devices into DEP on the Apple side and then assign settings to them in Dashboard.
Once you've done this, you can wipe each device and it will become supervised and get the DEP profile during the setup process. If you want to restore data from iCloud or iTunes you can do that as well - just pick the appropriate option on the restore screen.
MRCUR | CMNO #12
Well, i'm struggling at simply getting the DEP profile onto freshly wiped ios devices, even though they are in Apple's DEP and [obviously] Meraki > DEP.
There has been conflicting info about whether pre-supervised devices can be DEP supervised then restored as the theory is that the backup state was unsupervised so that is what would be put back on the device.
Think the jury is still out on that isn't it?
@Jacko DEP happens *after* the restore process in the iOS setup. This means you can take a device in any state, wipe it, restore from backup and have DEP applied.
Are you sure you've applied DEP settings in Dashboard to the devices? Does DEP happen if you don't do a restore?
MRCUR | CMNO #12
Ok what's confused me is that, it does restore but doesn't add the wifi SSID that i assigned in the Apple Config profile.
So, ok it restores, i have to go through some of the necessary steps to get to the "remote management' screen, which is then where it grabs the DEP profile and then subsequently according to what tags are assigned to the device in Meraki dashboard it will then assign a 'settings' profile which can be updated and rolled out whithout rebooting/wiping.
Am i correct so far?
If so, then how do you make a touchless deployment whereby it adds the wifi SSID so you don't have to. Is that only done in Apple Configurator?
@Jacko Yes, I believe you're required to use Apple Configurator to do a touchless deployment. @jared_f probably has a better handle on that than I do as we simply use an open "enrollment" SSID when setting up iOS devices.
MRCUR | CMNO #12
Thanks, that may not be such an issue i guess.
Just trying to automate the process as much as possible.
One thing i've found is that after a supervised enrolment i cannot access users account settings on iphone or ipad. i cant see in the profiles where that area is allowed/disallowed.
If disallowed then the devices surely can't back up to icloud?
Hope this helps!
Hi All!
Restoring from a backup is possible with DEP devices. During DEP the device becomes managed and supervised no matter what. Please have your users make a backup, add the device to DEP with Apple Configrator 2, and assign DEP settings within Meeaki before the user starts setup.
I plan on writing a guide and doing a video walk through if possible to clear this matter up!
jared
Good point - once the device is supervised, restore from backup will work in the future on that device. The issue is restoring from backup when the backup was made on an unsupervised device (when trying to move to a supervised state).
@Melissa,
This seems to be my experience as well, although my experience is limited.  Here is my scenario:
I had an iPhone 6s that was unsupervised and unmanaged.  I backed up to iCloud.
My new iPhone 8 was enrolled in DEP and assigned to Meraki with a Supervised/Mandatory profile.  In going through initial setup on the new phone, I chose restore from iCloud.  After completing setup, the device was not supervised or managed, and I never received any screen that would indicate anything was coming in from DEP.  So, I did a few experiments.
1.  Updated iOS on the phone, wiped the phone (it kept the iOS update) and tried the restore again.  Didn't make any difference.
2.  Ran through the setup on the iPhone 8 without a restore.  Phone was Supervised and enrolled and Meraki app pushed as it should have been.
3.  Wiped the phone and tried with the restore again.  Still no go.
4.  Restored the same backup to a DEP Supervised/Mandatory iPhone 6S instead of the new iPhone 8.  This WORKED!
5.  Backed up from this now Supervised iPhone 6s to iCloud.
6.  Restored from this supervised backup to the new iPhone 8.  This worked.
I'm thinking something new was introduced with iPhone 8 that prevents the DEP push when restoring from an unsupervised device.
If someone else has the equipment to try the same experiment, I would love to see if my scenario can be duplicated.
@CherylA That may be the case. Seems to be working fine with the iPads. I believe we should open a support case with Apple. It is very problematic if what you are saying is true.
It looks like there is a patch for this.
@PhilipDAth Your "patch" link just goes to the android open source website.  No relevance to Apple iOS / DEP.
It was making a wry joke.
@PhilipDAth I thought maybe you were joking, but you had my hopes up there for a second! 🙂
@PhilipDAth I laughed 😉
I will monitor my post on the other community. I am also going to reachout to my buisness team at Apple and see what there support states.
It might also be interesting to peek into other MDM forums to see if other MDMs are seeing the same thing 😉  If they are, it seems like that would point back to Apple.
I reached out to a friend at Jamf. Hoping to get some clarity. This has been really bugging me lol.
Apple seems to put safe guards in place so we as admins don't abuse power, but they also make things difficult at points too.
Jared
@CherylA Just to verify, did you remove the Meraki MDM profile from your 6S before restoring it to your new phone?
@jared_f
No, I didn't remove the profile from the 6s before restoring the backup to the 8.
@CherylA That may be your issue.
@jared_f I doubt that's the issue. Here is what I found out from Apple on this process:
Here is a key piece:
'If you erase the device and restore the backup, the device remains unsupervised and the user can remove management. If you restore the backup to a different device that is assigned to the server, the device is supervised and the user can’t remove management.'
Essentially, for you want to restore an iCloud backup, you need to restore it to a different device to retain Supervision and DEP."
@CherylA This would explain your results as well!! It sounds like this is something Apple is trying to fix. Hopefully there is a better solution soon.
