Meraki dashboard change
Hi All,
Am I the only one who's Dashboard got changed? In one of my MX65 Uplink tab the Historical data part went from the normal dark and light blue to yellow and even lighter blue.
I mean I don't really mind this change, but the legend has disappeared, and I'm pretty sure that a link can't drop more than 100% of packet. I have sites which showing packet loss peaks up to 200%.
Yesterday this was perfectly normal for me. Is this a new visual bug?
Cheers,
Greg
Accepted Solutions
Re: Meraki dashboard change
Hi All,
I am confirming that this appears to be a bug and our developers' team are looking into this.
@GergelyK Thanks for bringing attention to this 🙂
Cheers!
Raj
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it
13 REPLIES 13
Not, its not only you 😉
well I´ve got a peak which looks like 100% on a site as well, but when I hover over it, it only shows 30%
Well, that's good news I guess that it's not only me/us.
Did you maybe know why is this happening, or should we get in touch with TAC?
Also I just noticed that the topic is in the wrong subject.
I'm sorry about it. If an admin comes around here, can move this topic under "Dashboard & Administration"? 🙂
Thank you.
Hi All,
I've reported this out to Meraki TAC.
They came back to me that they are checking this with the developer team.
Cheers,
Greg
I'm seeing this as well with it showing packet loss of up to 1000% and above!
We are loosing from another circuit as well. 🙂
Community Manager
Moved!
Caroline S | Community Manager, Cisco Meraki | @merakicaroline
Hi All,
Cheers!
Raj
Good thing we don't have a staff review today, my boss would have a heart attack seeing this:
Good to know Meraki is already looking into it.
Hello All,
The issue has been fixed. I just received the confirmation. 🙂
@Raj66 Thanks for the fast reply, and fix. 🙂
Thanks for reporting back @GergelyK .
