Search instead for
Major Outage
Major Outage
I am seeing across many shards an outage in the dashboard functionality.  We can't bring up clients or their networks or see their devices.
I have contacted support and they have confirmed there is an issue.
Accepted Solutions
Re: Major Outage
After an internal investigation, Cisco Meraki has found the source of the problem which caused an outage of the Meraki dashboard between 9pm and 10:30pm PDT on 8/12. We found that errors in the integration process for dashboard resulted in frontend code being deployed which was no longer compatible with the dashboard application and backend. This issue was resolved and the processes that allowed this issue are currently being improved to prevent problems like this in the future.
Alex S | Cisco Meraki Product Management - Cloud
33 REPLIES 33
Re: Major Outage
I was part way through a site wide switch firmware upgrade.  The whole site has been taken out, and the firmware upgrades have stopped.  Some stack members completed the download, some didn't.
Worst possible timing.
Re: Major Outage
Re: Major Outage
Same here @PhilipDAth . I am in the middle of LDAP integration.
Cheers
Ajit
ajitsnw@gmail.com
Re: Major Outage
Same here..
Re: Major Outage
Confirmed here is Australia as well.
If it makes you feel any better @PhilipDAth , we were part way commissioning a new site with 50+ cameras, 15+ APs and switches.
We have stopped now until this is resolved.
Re: Major Outage
Did your upgrade take out the dashboard for all of us? =)
Re: Major Outage
Nope.  :-(
Re: Major Outage
Seeing the same issue in Chicago.
Re: Major Outage
This is obviously a serious global outage affecting either the majority or all shards.
Re: Major Outage
Lets flip this around - anyone in the world still have their dashboard working?
Re: Major Outage
Yeah ours died too. Funny thing was a team mate was doing his very first Meraki device and of course it died whilst he touched it. So we blamed him for breaking it Smiley Very Happy
Re: Major Outage
nope. our's is not working either.
Re: Major Outage
Makes me feel safe and secure.
Re: Major Outage
This is actually a security enhancement.
Re: Major Outage
We are back online.
Re: Major Outage
Yup us too.
Re: Major Outage
Everything looks happy to me as well now.
Re: Major Outage
Everything up and running (again)
Re: Major Outage
@MeredithW @CarolineS Do you know something about it or can tell us who could tell us about, what the problem was?
Seemed like a bigger problem O_o Interessting
Re: Major Outage
Same chatter on Reddit.
Users on reddit report that, it could look like Meraki outage happened at the same time as a Level3 outage. Meraki might use Level3 somewhere.
Re: Major Outage
You mean this post, 2 Years ago? Smiley Wink
27
Outage this morning?
Anyone else get notified that their AP's went down/up this morning? Ours self-reported an outage from 7:00-7:35 A.M. EDT.
Re: Major Outage
dashboard is up and running again.
But we don't see the number of networks on the map. Usually we have there some big (mostly) green bubbles showing the number of regional networks.
This is missing, since the management services are up again.
Anybody else seeing this behaviour, too?
Just browsing
Re: Major Outage
Can anyone confirm that the Threat Protection in Security & SD WAN is not working? The page is just loading.
Re: Major Outage
confirmed from Germany.
Re: Major Outage
Yes, confirmed.
Re: Major Outage
27
Meh...
*mumbles something about more coffee...*
Re: Major Outage
confirmed in UK - just posted another thread about this problem.
Also, the Site/Network location markers are missing from the Overview map too Smiley Sad
Re: Major Outage
and our map is zooming always to Africa. Though, we have no networks there...
Case is open with Meraki
Re: Major Outage
As all seems to be fine again, does anyone know what caused the problems?
Re: Major Outage
The Meraki cloud engineering and PM team are still investigating this issue. We believe this is resolved now but are still digging into the root cause. I will update this thread later when we have more information.
Re: Major Outage
En México tuvimos la misma afectación se escalo con el soporte de Cisco Meraki y nos comentan lo siguiente.
Saludos,
Gracias por contactar soporte Cisco Meraki!
El problema de visibilidad al portal de Dashboard se debió a problemas en nuestro backend registrados en el día de ayer alrededor de las 21:50 PDT. El problema fue rectificado y los servicios re-establecidos nuevamente.
Favor de notar que durante esta eventualidad los equipos no perdieron funcionalidad, solo el acceso a la plataforma de configuración estaba fuera de servicio.
Si tienes alguna pregunta al respecto no dudes en contactarnos.
Re: Major Outage
Sounds like yesterday was a good excercise in maintenance mangement for everyone. Hope you all had good plans in place Smiley Tongue
Re: Major Outage
