Add MDM to existing Network
nealgs
Hi All in Meraki land,
Wanting to add MDM to an existing network - is it possible other than by creating new network and combining them?
Currently using the Legacy version on 2 networks but they are themselves separate networks.  Want to bring each locations MDM into their respective Network but can't see any option when in a selected network to add it.
cheers all 🙂
kYutobi
In your menu select "View All Networks" from there you can select the MDM and Network you want and hit Combine. You do not have to create a new network. Just combine the existing.
Enthusiast
nealgs
Thanks kYutobi
I was aware of the combine for existing networks, this is more for adding MDM to an existing network.
There is no option i can see to create a new MDM in a network that is already there.  You have to create a new MDM network and then do the combine option rather than just adding to a network that already exists directly - unless i'm missing something 🙂
cheers
Gary
BlakeRichardson
@nealgs Yes you may need to create a new EMM newtwork and then combine it with an exisiting network if you want everything in a single network.
