different RADIUS servers but same SSID name and settings
InfraEngineer20
Not sure if this has been asked, but we have different RADIUS servers with the same key, but each network has the same SSID name and settings as each other just the RADIUS servers being different per network, when a user goes from one network to another they have to re-connect to the hidden SSID that we have, our public showing SSID is no issues when roaming as this uses Meraki DHCP not our internal DHCP.
Any advice on getting it so clients can move across the different networks without having to re-connect to the hidden SSID
6 Replies 6
Generally hiding SSID is not recommended. It can lead to slower association time for certain client types that can have an impact on client roaming.
InfraEngineer20
hi, thanks for your reply, im thinking about doing the layer 3 option, would this still cause an issue on the clients connecting to the SSID if still hidden
TBHPTL
Is it truly  separate "networks" or are the AP's in one physical location? Why do you need two differing  RADIUS servers; is either RADIUS server not reachable from the LAN at either site?
InfraEngineer20
we have AP's on different sites with DC's on each site with there own RADIUS setup
The Radius is not the issue here. I suggest you do a test without hiding the SSID.
BlakeRichardson
Some OS don't handle hidden SSID well. You are better to leave visible and have decent encryption. Also I wouldn't recommend using the same shared secret for multiple Radius servers it's not a good security practise.
