Unable to connect SONOS One SL
NeedHelp1
We are trying to connect our two SONOS ONE SL speakers to our wireless internet/fiber connection, but it seems as though some firewall (or similar) are blocking the configuration and thus the SONOS spearkers are unable to connect to the WiFi.
Has someone had this issue before or does someone know what we can do to configure this connection correctly?
ConnorL
https://community.meraki.com/t5/Wireless/Connecting-Sonos-to-Meraki/m-p/83638/highlight/true#M12579
Tl;dr - make sure you're on the same VLAN and you have Wireless > Firewall and Traffic Shaping" Wireless clients accessing LAN" set to allow.
Robthesoundguy
+1 for this. Sonos uses mDNS which doesn't cross VLAN boundaries.
Brash
To clarify, Bonjour forwarding can be used to have mDNS cross L3 boundaries
Bonjour Forwarding - Cisco Meraki Documentation
However from my experience, it can be a bit unreliable/slow.
The SSID will need to be in "bridged" mode as well.
