Specific AP having radius server did not respond issue
Keith_Li
Dear All,
              Would like to seek for help on the following, one of our customer are using Meraki MR44 AP, and with 2 ssid created call "Internal" & "Visitor", ssid internal are authenticated with Radius server, and ssid visitor are authenticated via PSK, and it was working fine with both ssid, and in recent day our customer reported there is one AP having authenticated issue on the ssid "Internal", and below is the logs i found, i have tried to ping the radius server ip from the problem AP, and it could reach the radius server, but below logs are still appearing, just wonder is there anything i can do to fix such issue ? any help would be appreicated
Client failed during the authentication step.
reason='reserved' radio='1' vap='0' channel='40' rssi='49'
Client made an 802.1X authentication request to the RADIUS server, but it did not respond.
radius_ip='188.3.8.201' reason='radius_timeout' radio='1' vap='0' channel='40' rssi='28'
Keith
GIdenJoe
You didn't need the host , only radius communicates on that port.
If your AP does not send anything when the client connects to it (so be sure it is a new session, not a roam) then the AP is not doing anything towards the radius servers.
Another important note though:  Dashboard captures can be a bit finnicky and it is possible your capture stopped capturing packets a long time ago.  It is best if you use dashboard captures that you keep to the 30 seconds to 60 seconds mark and immediately try to connect.
15 Replies 15
Brash
A few things to check would be:
 - That there's no ports blocked between AP and RADIUS server
 - That the AP's IP Address is configured in the RADIUS server as an allowed client it will accept requests from
A few other things you can try are running a RADIUS test from the dashboard (https://documentation.meraki.com/MR/Encryption_and_Authentication/Configuring_RADIUS_Authentication_...) and checking the logs on the RADIUS server
Keith_Li
any idea that only 1 AP having such issue, and the rest are working fine with ssid "internal" ?
Brash
Multiple.
Firewall rules, RADIUS config to name a few.
As I said, there's a few things to check that should help narrow it down.
AxL1971
I would perform a packet capture on the AP
Also on the RADIUS server, have you checked the logs
We had a similair issue with our Cisco ISE server where as same issue as yourself in the end a reboot of the ISE box resolved the issue
JohanPlukon
Maybe the password given in the Meraki dashboard radius configuration does not match with Radius?
RaphaelL
Check your Radius logs, was the request received on your radius server ? Did the radius server actually responded to the query ?
 I have an open ticket open for months regarding these ''errors''. Sometime if the Radius server reject the auth ( access-reject ) , Meraki will log it as 'Client made an 802.1X authentication request to the RADIUS server, but it did not respond.'  in fact the radius server DID respond , but with an access-reject.
It might be the same issue.
Keith_Li
I will need to ask customer to check their radius server, may I ask your case is only specific AP having such issue ? Actually I check all AP in customer sites I see such logs keep on occurring
RaphaelL
It was affecting some of our APs and random auths during the day. There was no specific behavior.
If you can be 100% sure that these logs are only affecting 1 device then I'm affraid it might be different than my case but I still suggest to do a packet capture , look at the radius logs and so on. Would be the best way to troubleshoot it imo.
Keith_Li
i will try to do data packet capture on meraki dashboard, may i share it out the capture result and guide me how to check the issue in the logs ?
RaphaelL
Yes you may. Just be careful not including sensitive trafic in the packet capture
AxL1971
Download the pcap file and load it up in Wireshark.
Keith_Li
below are the packet capture
--- Start Of Stream ---
03:22:05.509187 unknown 802.11 ctrl frame subtype (3)
03:22:05.509323 Beacon (DKT-Staff-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.511462 unknown 802.11 ctrl frame subtype (1)
03:22:05.511574 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.512175 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.513307 BA RA:fa:c4:92:c6:ab:dd
03:22:05.513566 [|802.11]
03:22:05.514637 unknown 802.11 frame type (3)
03:22:05.515771 unknown 802.11 ctrl frame subtype (5)
03:22:05.516319 Probe Response (MFC-Agency) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] CH: 108
03:22:05.516665 Probe Response (MFC-Agency) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] CH: 108
03:22:05.516684 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.517689 BA RA:fa:c4:92:c6:ab:dd
03:22:05.518058 Beacon[|802.11]
03:22:05.519246 Request-To-Send TA:d1:15:a6:ca:36:a0
03:22:05.519533 Acknowledgment RA:ee:00:1e:54:84:74
03:22:05.519573 unknown 802.11 ctrl frame subtype (5)
03:22:05.519728 Request-To-Send TA:d1:15:a6:ca:36:a0
03:22:05.519961 Beacon (DKT-Staff-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.520838 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.520875 Request-To-Send TA:d1:15:a6:ca:36:a0
03:22:05.521275 Request-To-Send TA:d1:15:a6:ca:36:a0
03:22:05.522793 BA RA:fa:c4:92:c6:ab:dd
03:22:05.523030 Beacon (MFC-Agency) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 108[|802.11]
03:22:05.523157 Request-To-Send TA:d1:15:a6:ca:36:a0
03:22:05.523437 Request-To-Send TA:d1:15:a6:ca:36:a0
03:22:05.523956 IP 192.168.147.239.137 > 192.168.159.255.249: UDP, length 50
03:22:05.524460 Beacon (Jguest) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 108
03:22:05.525911 Beacon (Jmeeting) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 108[|802.11]
03:22:05.526290 [|802.11]
03:22:05.526872 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.527042 Unhandled Management subtype(e)
03:22:05.527296 BA RA:a6:46:8d:1a:4d:12
03:22:05.527372 Request-To-Send TA:d1:15:a6:ca:36:a0
03:22:05.527477 BA RA:a6:46:8d:1a:4d:12
03:22:05.528809 Request-To-Send TA:d1:15:a6:ca:36:a0
03:22:05.528963 Probe Request[|802.11]
03:22:05.529369 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.529665 Data IV:7abf Pad 20 KeyID 0
03:22:05.533635 Request-To-Send TA:d1:15:a6:ca:36:a0
03:22:05.533838 Request-To-Send TA:d1:15:a6:ca:36:a0
03:22:05.535040 CF-End RA:ff:ff:ff:ff:ff:ff
03:22:05.535326 Request-To-Send TA:d1:15:a6:ca:36:a0
03:22:05.535897 Request-To-Send TA:d1:15:a6:ca:36:a0
03:22:05.537536 unknown 802.11 ctrl frame subtype (5)
03:22:05.537687 Unhandled Management subtype(e)
03:22:05.538353 Request-To-Send TA:d1:15:a6:ca:36:a0
03:22:05.539234 Request-To-Send TA:d1:15:a6:ca:36:a0
03:22:05.540016 BA RA:a6:46:8d:1a:4d:12
03:22:05.540109 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.540412 Request-To-Send TA:d1:15:a6:ca:36:a0
03:22:05.541280 Data IV:7ac0 Pad 20 KeyID 0
03:22:05.542424 ReAssoc Request IV:4d77e6 Pad 28 KeyID 3
03:22:05.542580 Unhandled Management subtype(e)
03:22:05.542791 Data IV:17a Pad 20 KeyID 0
03:22:05.543705 BA RA:a6:46:8d:1a:4d:12
03:22:05.543885 unknown 802.11 ctrl frame subtype (5)
03:22:05.544729 [|802.11]
03:22:05.545179 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.546692 Request-To-Send TA:d1:15:a6:ca:36:a0
03:22:05.546908 Data IV:7ac1 Pad 20 KeyID 0
03:22:05.548104 Clear-To-Send RA:a8:bd:27:18:80:95
03:22:05.548693 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.548730 Request-To-Send TA:d1:15:a6:ca:36:a0
03:22:05.548857 Unhandled Management subtype(e)
03:22:05.549172 BA RA:a6:46:8d:1a:4d:12
03:22:05.550055 Request-To-Send TA:d1:15:a6:ca:36:a0
03:22:05.550656 Acknowledgment RA:b8:09:8a:c4:b8:f9
03:22:05.551006 Request-To-Send TA:d1:15:a6:ca:36:a0
03:22:05.551960 [|802.11]
03:22:05.552160 Request-To-Send TA:d1:15:a6:ca:36:a0
03:22:05.552561 Request-To-Send TA:d1:15:a6:ca:36:a0
03:22:05.553759 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.553795 Unhandled Management subtype(e)
03:22:05.554566 BA RA:a6:46:8d:1a:4d:12
03:22:05.555861 Beacon (DKT-Guest-WiFi) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 108
03:22:05.555897 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.556590 IP 192.168.148.58.57967 > 224.0.0.252.5355: UDP, length 33
03:22:05.557203 Data IV:7ac2 Pad 20 KeyID 0
03:22:05.557941 Beacon (MFC-Agency) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 108
03:22:05.558665 Beacon (DKT-Guest-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1
03:22:05.560586 IP 192.168.148.58.57967 > 224.0.0.252.5355: UDP, length 33
03:22:05.560618 Unhandled Management subtype(e)
03:22:05.560843 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.561956 BA RA:a6:46:8d:1a:4d:12
03:22:05.562956 [|802.11]
03:22:05.562972 Beacon (DKT-Staff-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.563503 Unhandled Management subtype(e)
03:22:05.563612 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.565226 BA RA:fa:c4:92:c6:ab:dd
03:22:05.565890 unknown 802.11 ctrl frame subtype (5)
03:22:05.566393 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.566628 Unhandled Management subtype(e)
03:22:05.567093 BA RA:a6:46:8d:1a:4d:12
03:22:05.568211 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.568894 BA RA:fa:c4:92:c6:ab:dd
03:22:05.569080 Action IV:f9b4d6 Pad 12 KeyID 1
03:22:05.569187 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.570213 BA RA:fa:c4:92:c6:ab:dd
03:22:05.571094 CF-End RA:ff:ff:ff:ff:ff:ff
03:22:05.572460 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.575957 unknown 802.11 ctrl frame subtype (5)
03:22:05.576123 Beacon (MFC) [1.0* 2.0* 5.5* 11.0* 6.0 9.0 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.578203 Acknowledgment RA:42:34:57:12:4c:b1
03:22:05.578233 Beacon (DKT-Guest-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1
03:22:05.580590 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.580622 unknown 802.11 ctrl frame subtype (5)
03:22:05.580747 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.581962 Beacon (DKT-Staff-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.584869 Acknowledgment RA:34:e1:2d:62:6b:41
03:22:05.584898 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.585652 BA RA:fa:c4:92:c6:ab:dd
03:22:05.586909 [|802.11]
03:22:05.589433 unknown 802.11 ctrl frame subtype (5)
03:22:05.589716 unknown 802.11 ctrl frame subtype (0)
03:22:05.589796 Beacon (MSI5G) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS, PRIVACY
03:22:05.590876 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.591514 unknown 802.11 ctrl frame subtype (5)
03:22:05.591530 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.592517 BA RA:fa:c4:92:c6:ab:dd
03:22:05.593337 Acknowledgment RA:94:53:30:64:9e:df
03:22:05.594181 Beacon () [11.0* 12.0 18.0 24.0 36.0 48.0 54.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.594449 unknown 802.11 ctrl frame subtype (5)
03:22:05.594512 Data IV:b70f Pad 20 KeyID 2
03:22:05.594818 Data IV:b710 Pad 20 KeyID 2
03:22:05.595046 Data IV:b712 Pad 20 KeyID 2
03:22:05.597314 unknown 802.11 ctrl frame subtype (5)
03:22:05.597430 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.598447 BA RA:fa:c4:92:c6:ab:dd
03:22:05.598465 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.598619 Data IV:b714 Pad 20 KeyID 2
03:22:05.601531 unknown 802.11 ctrl frame subtype (5)
03:22:05.601715 Unhandled Management subtype(e)
03:22:05.601752 BA RA:a6:46:8d:1a:4d:12
03:22:05.604032 Clear-To-Send RA:61:d7:9c:c6:ab:dd
03:22:05.604139 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.604302 Data IV:7ac3 Pad 20 KeyID 0
03:22:05.605328 Beacon (MFC-Agency) [1.0* 2.0* 5.5 11.0 6.0 9.0 12.0 18.0 Mbit] ESS CH: 1
03:22:05.607178 unknown 802.11 ctrl frame subtype (5)
03:22:05.607286 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.607389 Beacon (DKT-Guest-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1
03:22:05.608203 BA RA:fa:c4:92:c6:ab:dd
03:22:05.608316 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.609570 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.610254 BA RA:fa:c4:92:c6:ab:dd
03:22:05.611050 unknown 802.11 ctrl frame subtype (5)
03:22:05.611626 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.611781 Unhandled Management subtype(e)
03:22:05.612271 BA RA:a6:46:8d:1a:4d:12
03:22:05.612848 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.613072 Unhandled Management subtype(e)
03:22:05.613235 BA RA:a6:46:8d:1a:4d:12
03:22:05.614636 BA RA:a6:46:8d:1a:4d:12
03:22:05.614753 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.614842 unknown 802.11 ctrl frame subtype (5)
03:22:05.614902 BA RA:fa:c4:92:c6:ab:dd
03:22:05.614994 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.615963 Data IV:7ac4 Pad 20 KeyID 0
03:22:05.615995 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.616145 Unhandled Management subtype(e)
03:22:05.616313 [|802.11]
03:22:05.616352 BA RA:a6:46:8d:1a:4d:12
03:22:05.616399 Beacon (DKT-Staff-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.616506 BA RA:a6:46:8d:1a:4d:12
03:22:05.616790 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.616819 Request-To-Send TA:5c:80:b6:46:f9:97
03:22:05.616944 Data IV:7ac5 Pad 20 KeyID 0
03:22:05.616971 Request-To-Send TA:5c:80:b6:46:f9:97
03:22:05.616984 Clear-To-Send RA:5c:80:b6:46:f9:97
03:22:05.617118 Acknowledgment RA:5c:80:b6:46:f9:97
03:22:05.617446 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.617637 Unhandled Management subtype(e)
03:22:05.617963 BA RA:a6:46:8d:1a:4d:12
03:22:05.618382 Beacon (DKT-Guest-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1
03:22:05.618865 unknown 802.11 ctrl frame subtype (5)
03:22:05.619387 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.619957 Unhandled Management subtype(e)
03:22:05.619986 BA RA:a6:46:8d:1a:4d:12
03:22:05.619998 BA RA:a6:46:8d:1a:4d:12
03:22:05.620476 BA RA:a6:46:8d:1a:4d:12
03:22:05.620577 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.621052 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.621283 Unhandled Management subtype(e)
03:22:05.621467 BA RA:a6:46:8d:1a:4d:12
03:22:05.621857 BA RA:a6:46:8d:1a:4d:12
03:22:05.622631 Beacon (DKT-Staff-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.624813 unknown 802.11 ctrl frame subtype (5)
03:22:05.624832 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.624967 Unhandled Management subtype(e)
03:22:05.625937 BA RA:a6:46:8d:1a:4d:12
03:22:05.626511 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.626670 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.626720 Unhandled Management subtype(e)
03:22:05.626838 BA RA:a6:46:8d:1a:4d:12
03:22:05.627005 BA RA:a6:46:8d:1a:4d:12
03:22:05.627114 BA RA:a6:46:8d:1a:4d:12
03:22:05.627971 BA RA:a6:46:8d:1a:4d:12
03:22:05.628311 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.628592 Unhandled Management subtype(e)
03:22:05.629407 BA RA:a6:46:8d:1a:4d:12
03:22:05.631677 CF-End RA:ff:ff:ff:ff:ff:ff
03:22:05.634688 IP 192.168.148.58.57967 > 224.0.0.252.5355: UDP, length 33
03:22:05.635254 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.635386 Unhandled Management subtype(e)
03:22:05.635541 BA RA:a6:46:8d:1a:4d:12
03:22:05.636304 BA RA:a6:46:8d:1a:4d:12
03:22:05.636878 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.637021 Unhandled Management subtype(e)
03:22:05.637525 BA RA:a6:46:8d:1a:4d:12
03:22:05.637650 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.639460 BA RA:fa:c4:92:c6:ab:dd
03:22:05.639780 unknown 802.11 ctrl frame subtype (5)
03:22:05.639798 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.641919 Data IV:7ac6 Pad 20 KeyID 0
03:22:05.641942 Data IV:7ac7 Pad 20 KeyID 0
03:22:05.641958 Data IV:7ac8 Pad 20 KeyID 0
03:22:05.641980 Data IV:7ac9 Pad 20 KeyID 0
03:22:05.642000 Data IV:7aca Pad 20 KeyID 0
03:22:05.642089 Unhandled Management subtype(e)
03:22:05.642471 BA RA:a6:46:8d:1a:4d:12
03:22:05.642593 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.643303 BA RA:fa:c4:92:c6:ab:dd
03:22:05.643572 Acknowledgment RA:14:de:16:9b:8c:4c
03:22:05.644752 unknown 802.11 ctrl frame subtype (5)
03:22:05.645982 unknown 802.11 ctrl frame subtype (5)
03:22:05.646468 unknown 802.11 ctrl frame subtype (0)
03:22:05.647545 unknown 802.11 ctrl frame subtype (5)
03:22:05.648134 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY[|802.11]
03:22:05.648305 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.648507 unknown 802.11 ctrl frame subtype (2)
03:22:05.648623 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.648761 Data IV:7acb Pad 20 KeyID 0
03:22:05.648775 Data IV:7acc Pad 20 KeyID 0
03:22:05.648797 Data IV:7acd Pad 20 KeyID 0
03:22:05.649406 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.649431 BA RA:fa:c4:92:c6:ab:dd
03:22:05.649642 [|802.11]
03:22:05.649916 CF-End RA:ff:ff:ff:ff:ff:ff
03:22:05.650091 Data IV:3ff8 Pad 20 KeyID 0
03:22:05.650337 Beacon [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] IBSS CH: 40[|802.11]
03:22:05.651567 Unhandled Management subtype(e)
03:22:05.651743 BA RA:a6:46:8d:1a:4d:12
03:22:05.652010 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.652199 Unhandled Management subtype(e)
03:22:05.652314 BA RA:a6:46:8d:1a:4d:12
03:22:05.652889 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.653033 Unhandled Management subtype(e)
03:22:05.653502 Beacon (JaN-guest-5) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 40
03:22:05.653819 BA RA:a6:46:8d:1a:4d:12
03:22:05.656085 Acknowledgment RA:42:34:57:12:4c:b1
03:22:05.656111 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.656911 Data IV:7ace Pad 20 KeyID 0
03:22:05.658982 Beacon (HLDStaff) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.659465 Beacon (DKT-Guest-WiFi) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 108
03:22:05.659885 Beacon (MFC-Agency) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 108
03:22:05.659961 Beacon (MFC) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 40, PRIVACY
03:22:05.661041 Beacon (DKT-Guest-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1
03:22:05.663230 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.663903 IP 192.168.146.74.53935 > 224.0.0.252.5355: UDP, length 24
03:22:05.665318 Beacon (DKT-Staff-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.667690 [|802.11]
03:22:05.668258 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.668400 Unhandled Management subtype(e)
03:22:05.668814 BA RA:a6:46:8d:1a:4d:12
03:22:05.668994 unknown 802.11 ctrl frame subtype (5)
03:22:05.669231 unknown 802.11 ctrl frame subtype (5)
03:22:05.669865 unknown 802.11 ctrl frame subtype (5)
03:22:05.669878 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.670261 unknown 802.11 ctrl frame subtype (5)
03:22:05.671995 Beacon IBSS, PRIVACY[|802.11]
03:22:05.673363 Unhandled Management subtype(e)
03:22:05.673477 Unhandled Management subtype(e)
03:22:05.673625 BA RA:a6:46:8d:1a:4d:12
03:22:05.674563 BA RA:fa:c4:92:c6:ab:dd
03:22:05.674684 Unhandled Management subtype(e)
03:22:05.674856 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.676303 Probe Response (MFC) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] CH: 40, PRIVACY
03:22:05.677633 [|802.11]
03:22:05.678092 BA RA:a6:46:8d:1a:4d:12
03:22:05.678179 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.680038 Beacon (MFC) [1.0* 2.0* 5.5* 11.0* 6.0 9.0 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.680594 Data IV:7acf Pad 20 KeyID 0
03:22:05.680607 Data IV:7ad0 Pad 20 KeyID 0
03:22:05.681474 Acknowledgment RA:42:34:57:12:4c:b1
03:22:05.681982 unknown 802.11 ctrl frame subtype (5)
03:22:05.682101 Beacon (DKT-Guest-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1
03:22:05.682929 unknown 802.11 ctrl frame subtype (5)
03:22:05.683503 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.683648 Unhandled Management subtype(e)
03:22:05.684283 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.685439 BA RA:a6:46:8d:1a:4d:12
03:22:05.685642 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.686783 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.687494 Unhandled Management subtype(e)
03:22:05.687521 BA RA:a6:46:8d:1a:4d:12
03:22:05.687732 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.687835 Unhandled Management subtype(e)
03:22:05.687948 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.689629 BA RA:a6:46:8d:1a:4d:12
03:22:05.690995 unknown 802.11 ctrl frame subtype (5)
03:22:05.691231 Unhandled Management subtype(e)
03:22:05.691992 unknown 802.11 ctrl frame subtype (5)
03:22:05.692176 Unhandled Management subtype(e)
03:22:05.693703 CF-End RA:ff:ff:ff:ff:ff:ff
03:22:05.693721 Request-To-Send TA:5c:80:b6:46:f9:97
03:22:05.693799 Clear-To-Send RA:fa:c4:92:c6:ab:bd
03:22:05.693831 Request-To-Send TA:5c:80:b6:46:f9:97
03:22:05.693842 Clear-To-Send RA:5c:80:b6:46:f9:97
03:22:05.693972 Acknowledgment RA:5c:80:b6:46:f9:97
03:22:05.694165 Beacon (DKT-Staff-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.695994 Beacon () [11.0* 12.0 18.0 24.0 36.0 48.0 54.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.696404 BA RA:fa:c4:92:c6:ab:dd
03:22:05.697048 Beacon () [11.0* 6.0 9.0 12.0 18.0 24.0 36.0 48.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.697256 unknown 802.11 ctrl frame subtype (5)
03:22:05.697474 Request-To-Send TA:ab:46:8d:1a:55:c2
03:22:05.697517 Clear-To-Send RA:aa:46:8d:1a:55:c2
03:22:05.697566 unknown 802.11 ctrl frame subtype (5)
03:22:05.697673 Unhandled Management subtype(e) IV:ad6def Pad 24 KeyID 3
03:22:05.697776 Unhandled Management subtype(e)
03:22:05.697842 Request-To-Send TA:aa:46:8d:1a:55:c2
03:22:05.697907 Clear-To-Send RA:aa:46:8d:1a:55:c2
03:22:05.699487 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.700995 Acknowledgment RA:94:53:30:64:9e:df
03:22:05.702122 BA RA:fa:c4:92:c6:ab:dd
03:22:05.702438 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.702524 Unhandled Management subtype(e)
03:22:05.702737 BA RA:a6:46:8d:1a:4d:12
03:22:05.704938 BA RA:a6:46:8d:1a:4d:12
03:22:05.705005 Clear-To-Send RA:fa:c4:92:c6:2b:17
03:22:05.705898 BA RA:d9:8f:7a:a7:9d:6f
03:22:05.707826 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.708742 Beacon (DKT-Guest-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1
03:22:05.709139 unknown 802.11 ctrl frame subtype (5)
03:22:05.709242 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.711833 unknown 802.11 ctrl frame subtype (5)
03:22:05.711911 BA RA:fa:c4:92:c6:ab:dd
03:22:05.712135 unknown 802.11 ctrl frame subtype (5)
03:22:05.712785 Acknowledgment RA:42:34:57:12:4c:b1
03:22:05.713590 Acknowledgment RA:0e:0a:0f:05:c9:91
03:22:05.714888 Acknowledgment RA:64:76:ba:9a:8c:4c
03:22:05.714971 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.715563 unknown 802.11 ctrl frame subtype (1)
03:22:05.715986 BA RA:fa:c4:92:c6:ab:dd
03:22:05.716009 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.717559 BA RA:fa:c4:92:c6:ab:dd
03:22:05.718589 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.719034 Beacon (FLD) [1.0* 2.0* 5.5* 11.0* 6.0 9.0 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.719667 unknown 802.11 ctrl frame subtype (5)
03:22:05.720453 unknown 802.11 ctrl frame subtype (5)
03:22:05.721479 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.721503 BA RA:fa:c4:92:c6:ab:dd
03:22:05.723016 Power Save-Poll AID(8d93)
03:22:05.723777 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.723796 BA RA:fa:c4:92:c6:ab:dd
03:22:05.725168 unknown 802.11 ctrl frame subtype (5)
03:22:05.725243 [|802.11]
03:22:05.725280 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.726633 unknown 802.11 ctrl frame subtype (5)
03:22:05.727124 BA RA:fa:c4:92:c6:ab:dd
03:22:05.727168 Unhandled Management subtype(e)
03:22:05.727339 Unhandled Management subtype(e)
03:22:05.727378 BA RA:a6:46:8d:1a:4d:12
03:22:05.727731 Request-To-Send TA:a6:46:8d:1a:4d:12
03:22:05.727780 BA RA:a6:46:8d:1a:4d:12
03:22:05.727807 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.727844 unknown 802.11 ctrl frame subtype (5)
03:22:05.728350 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.728433 Unhandled Management subtype(e)
03:22:05.728555 Unhandled Management subtype(e)
03:22:05.729164 BA RA:a6:46:8d:1a:4d:12
03:22:05.729360 Beacon ESS[|802.11]
03:22:05.729937 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.730265 Unhandled Management subtype(e)
03:22:05.730312 BA RA:a6:46:8d:1a:4d:12
03:22:05.730323 Request-To-Send TA:a6:46:8d:1a:4d:12
03:22:05.730332 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.730347 unknown 802.11 ctrl frame subtype (5)
03:22:05.730369 Unhandled Management subtype(e)
03:22:05.730392 BA RA:a6:46:8d:1a:4d:12
03:22:05.730505 BA RA:a6:46:8d:1a:4d:12
03:22:05.730642 BA RA:a6:46:8d:1a:4d:12
03:22:05.730767 BA RA:a6:46:8d:1a:4d:12
03:22:05.730857 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.730973 BA RA:a6:46:8d:1a:4d:12
03:22:05.730986 BA RA:a6:46:8d:1a:4d:12
03:22:05.730997 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.731011 Clear-To-Send RA:dc:37:14:cf:c9:53
03:22:05.731037 BA RA:dc:37:14:cf:c9:53
03:22:05.731760 Data IV:7ad1 Pad 20 KeyID 0
03:22:05.731790 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.731957 Unhandled Management subtype(e)
03:22:05.732110 BA RA:a6:46:8d:1a:4d:12
03:22:05.732149 Request-To-Send TA:a6:46:8d:1a:4d:12
03:22:05.732161 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.732181 unknown 802.11 ctrl frame subtype (5)
03:22:05.732203 Unhandled Management subtype(e)
03:22:05.732221 BA RA:a6:46:8d:1a:4d:12
03:22:05.732231 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.732271 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.732499 Data IV:7ad2 Pad 20 KeyID 0
03:22:05.732509 Data IV:7ad3 Pad 20 KeyID 0
03:22:05.732583 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.732884 Clear-To-Send RA:dc:37:14:cf:c9:53
03:22:05.732897 BA RA:dc:37:14:cf:c9:53
03:22:05.732905 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.732934 Clear-To-Send RA:dc:37:14:cf:c9:53
03:22:05.732947 BA RA:dc:37:14:cf:c9:53
03:22:05.732968 Request-To-Send TA:a6:46:8d:1a:4d:12
03:22:05.733043 Data IV:7ad4 Pad 20 KeyID 0
03:22:05.733067 Data IV:7ad5 Pad 20 KeyID 0
03:22:05.733638 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.733744 Unhandled Management subtype(e)
03:22:05.733934 BA RA:a6:46:8d:1a:4d:12
03:22:05.733995 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.734009 unknown 802.11 ctrl frame subtype (5)
03:22:05.734029 Unhandled Management subtype(e)
03:22:05.734056 BA RA:a6:46:8d:1a:4d:12
03:22:05.734076 BA RA:a6:46:8d:1a:4d:12
03:22:05.734193 BA RA:a6:46:8d:1a:4d:12
03:22:05.734266 BA RA:a6:46:8d:1a:4d:12
03:22:05.734350 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.735394 BA RA:a6:46:8d:1a:4d:12
03:22:05.735405 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.735414 Clear-To-Send RA:dc:37:14:cf:c9:53
03:22:05.735437 BA RA:dc:37:14:cf:c9:53
03:22:05.735628 Data IV:7ad6 Pad 20 KeyID 0
03:22:05.735704 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.736281 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.736291 Clear-To-Send RA:dc:37:14:cf:c9:53
03:22:05.736311 BA RA:dc:37:14:cf:c9:53
03:22:05.736325 Request-To-Send TA:a6:46:8d:1a:4d:12
03:22:05.736346 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.736852 Data IV:7ad7 Pad 20 KeyID 0
03:22:05.736871 Data IV:7ad8 Pad 20 KeyID 0
03:22:05.736909 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.736953 Unhandled Management subtype(e)
03:22:05.737146 BA RA:a6:46:8d:1a:4d:12
03:22:05.737231 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.737262 unknown 802.11 ctrl frame subtype (5)
03:22:05.737282 Unhandled Management subtype(e)
03:22:05.737299 BA RA:a6:46:8d:1a:4d:12
03:22:05.737309 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.737328 Clear-To-Send RA:dc:37:14:cf:c9:53
03:22:05.737615 Data IV:7ad9 Pad 20 KeyID 0
03:22:05.737634 Data IV:7ada Pad 20 KeyID 0
03:22:05.737821 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.737845 BA RA:fa:c4:92:c6:ab:dd
03:22:05.738771 BA RA:fa:c4:92:c6:ab:dd
03:22:05.739020 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.739085 Data IV:7adb Pad 20 KeyID 0
03:22:05.739127 BA RA:dc:37:14:cf:c9:53
03:22:05.739137 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.739159 Clear-To-Send RA:dc:37:14:cf:c9:53
03:22:05.739170 BA RA:dc:37:14:cf:c9:53
03:22:05.740411 unknown 802.11 ctrl frame subtype (5)
03:22:05.741487 unknown 802.11 ctrl frame subtype (5)
03:22:05.741988 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.742020 BA RA:fa:c4:92:c6:ab:dd
03:22:05.742250 Unhandled Management subtype(e)
03:22:05.742280 Unhandled Management subtype(e)
03:22:05.742291 BA RA:a6:46:8d:1a:4d:12
03:22:05.744322 BA RA:a6:46:8d:1a:4d:12
03:22:05.744355 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.744367 Clear-To-Send RA:dc:37:14:cf:c9:53
03:22:05.744431 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.744496 BA RA:dc:37:14:cf:c9:53
03:22:05.745452 Data IV:7adc Pad 20 KeyID 0
03:22:05.747642 Beacon (MFC-Agency) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 104[|802.11]
03:22:05.748198 20:0d:b0:c0:d2:6c > 01:00:5e:00:00:fc SNAP, oui Unknown (0xc03c02), pid Unknown (0xa8b2), length 52:
0x0000: aaaa 03c0 3c02 a8b2 ecd8 a586 6fe8 39b2 ....<.......o.9.
0x0010: ffef 7959 19e0 2d81 fc09 00fc d2af 14eb ..yY..-.........
0x0020: 0020 590e 2ce6 0000 0001 0000 0000 0000 ..Y.,...........
0x0030: 06c9 9196 7a61 7000 0001 0001 ....zap.....
03:22:05.748298 unknown 802.11 frame type (3)
03:22:05.748675 Request-To-Send TA:a6:46:8d:1a:4d:12
03:22:05.748762 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.748797 unknown 802.11 ctrl frame subtype (5)
03:22:05.749292 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.749422 Unhandled Management subtype(e)
03:22:05.749451 Unhandled Management subtype(e)
03:22:05.749470 BA RA:a6:46:8d:1a:4d:12
03:22:05.749861 unknown 802.11 ctrl frame subtype (5)
03:22:05.750360 BA RA:a6:46:8d:1a:4d:12
03:22:05.750774 Unhandled Management subtype(e)
03:22:05.750821 Unhandled Management subtype(e)
03:22:05.750833 BA RA:a6:46:8d:1a:4d:12
03:22:05.751161 Request-To-Send TA:a6:46:8d:1a:4d:12
03:22:05.751173 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.751183 unknown 802.11 ctrl frame subtype (5)
03:22:05.751192 BA RA:a6:46:8d:1a:4d:12
03:22:05.751568 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.751675 Unhandled Management subtype(e)
03:22:05.752327 IP 192.168.148.58.137 > 192.168.159.255.137: UDP, length 50
03:22:05.753218 BA RA:a6:46:8d:1a:4d:12
03:22:05.753349 Unhandled Management subtype(e)
03:22:05.753397 Unhandled Management subtype(e)
03:22:05.753422 BA RA:a6:46:8d:1a:4d:12
03:22:05.753433 unknown 802.11 ctrl frame subtype (5)
03:22:05.753459 Unhandled Management subtype(e)
03:22:05.753478 BA RA:a6:46:8d:1a:4d:12
03:22:05.753501 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.753620 BA RA:a6:46:8d:1a:4d:12
03:22:05.753648 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.753700 Beacon (TP-Link_0F4A) [1.0* 2.0* 5.5* 11.0* 9.0 18.0 36.0 54.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.753742 Clear-To-Send RA:dc:37:14:cf:c9:53
03:22:05.753753 BA RA:dc:37:14:cf:c9:53
03:22:05.754016 Beacon (HLDStaff) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.756268 Unhandled Management subtype(6) IV:ca7fcd Pad 0 KeyID 3
03:22:05.759340 Data IV:7add Pad 20 KeyID 0
03:22:05.761134 Beacon (DKT-Guest-WiFi) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 108
03:22:05.761850 Probe Response (DKT-Guest-WiFi) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] CH: 108
03:22:05.762251 Beacon (MFC-Agency) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 108
03:22:05.762331 IP 192.168.146.74.53935 > 224.0.0.252.5355: UDP, length 24
03:22:05.763440 Beacon (DKT-Guest-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1
03:22:05.764733 IP 192.168.148.58.137 > 192.168.159.255.137: UDP, length 50
03:22:05.765628 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.767031 ReAssoc Request[|802.11]
03:22:05.767146 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.767705 Beacon (DKT-Staff-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.768349 BA RA:fa:c4:92:c6:ab:dd
03:22:05.768603 unknown 802.11 ctrl frame subtype (1)
03:22:05.770812 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.771620 unknown 802.11 ctrl frame subtype (0)
03:22:05.771894 Beacon (TWF-2.4G) [1.0* 2.0* 5.5* 11.0* 6.0 9.0 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.772068 unknown 802.11 ctrl frame subtype (5)
03:22:05.772166 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.772301 BA RA:fa:c4:92:c6:ab:dd
03:22:05.772872 CF-End RA:ff:ff:ff:ff:ff:ff
03:22:05.773038 CF-End RA:ff:ff:ff:ff:ff:ff
03:22:05.777252 unknown 802.11 ctrl frame subtype (3)
03:22:05.777773 Beacon (MFC) [1.0* 2.0* 5.5* 11.0* 6.0 9.0 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.786789 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.787912 Request-To-Send TA:aa:46:8d:1a:4d:12
03:22:05.787984 unknown 802.11 ctrl frame subtype (5)
03:22:05.788019 unknown 802.11 ctrl frame subtype (5)
03:22:05.788140 Clear-To-Send RA:aa:46:8d:1a:4d:12
03:22:05.788279 Unhandled Management subtype(e)
03:22:05.788376 BA RA:aa:46:8d:1a:4d:12
03:22:05.790101 Request-To-Send TA:a7:46:8d:1a:4d:12
03:22:05.790161 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.790194 unknown 802.11 ctrl frame subtype (5)
03:22:05.790278 Unhandled Management subtype(e) IV:9115cb Pad 25 KeyID 0
03:22:05.790947 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.791051 Unhandled Management subtype(e)
03:22:05.791101 Unhandled Management subtype(e)
03:22:05.791250 Unhandled Management subtype(e)
03:22:05.791263 BA RA:a6:46:8d:1a:4d:12
03:22:05.791876 unknown 802.11 ctrl frame subtype (5)
03:22:05.792392 BA RA:a6:46:8d:1a:4d:12
03:22:05.792445 Request-To-Send TA:86:07:2f:85:bf:96
03:22:05.792468 Clear-To-Send RA:86:07:2f:85:bf:96
03:22:05.792560 Request-To-Send TA:86:07:2f:85:bf:96
03:22:05.792584 Unhandled Management subtype(e) IV:1be918 Pad 35 KeyID 2
03:22:05.792625 BA RA:86:07:2f:85:bf:96
03:22:05.793238 Data IV:904f Pad 0 KeyID 0
03:22:05.797119 [|802.11]
03:22:05.797977 Beacon (DKT-Staff-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.798351 Beacon () [11.0* 12.0 18.0 24.0 36.0 48.0 54.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.798431 c0:34:22:0c:22:2e Unknown SSAP 0x2a > 00:c0:e0:27:02:41 Unknown DSAP 0x1e Information, send seq 0, rcv seq 21, Flags [Final], length 28
0x0000: 1f2b 002b 411c 2f28 0c24 2b1f 2813 0c2c .+.+A./(.$+.(..,
0x0010: 1c1f 1f22 0800 f8bb 0000 e008 ..."........
03:22:05.798634 Beacon () [11.0* 6.0 9.0 12.0 18.0 24.0 36.0 48.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.798895 Data IV:b717 Pad 20 KeyID 2
03:22:05.799317 Data IV:b718 Pad 20 KeyID 2
03:22:05.799820 Data IV:b71a Pad 20 KeyID 2
03:22:05.799851 unknown 802.11 ctrl frame subtype (5)
03:22:05.800365 Acknowledgment RA:42:34:57:12:4c:b1
03:22:05.800521 Unhandled Management subtype(e)
03:22:05.800534 BA RA:a6:46:8d:1a:4d:12
03:22:05.800581 Unhandled Management subtype(e)
03:22:05.801146 Acknowledgment RA:0e:0a:0f:05:c9:91
03:22:05.801656 unknown 802.11 ctrl frame subtype (5)
03:22:05.802504 Data IV:b71c Pad 20 KeyID 2
03:22:05.802807 BA RA:a6:46:8d:1a:4d:12
03:22:05.802818 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.802849 Clear-To-Send RA:dc:37:14:cf:c9:53
03:22:05.802894 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.802943 BA RA:dc:37:14:cf:c9:53
03:22:05.803709 Data IV:7ade Pad 20 KeyID 0
03:22:05.804408 Clear-To-Send RA:10:0c:c8:18:ef:3b
03:22:05.804773 47:62:50:31:78:20 Unknown SSAP 0xb8 > 1f:21:42:e2:01:16 Unknown DSAP 0xac Unnumbered, 8b, Flags [Command], length 334
0x0000: adb8 8b65 db97 62db c000 a7a6 d6ed ded3 ...e..b.........
0x0010: 3228 14d3 d7ab 3635 5a3b bdcb d033 5da8 2(....65Z;...3].
0x0020: 7d36 5a4c e445 2afb db17 b4eb a77a 9a27 }6ZL.E*......z.'
0x0030: 600f e0fd 6906 886a fa52 ecf7 0262 9af9 `...i..j.R...b..
0x0040: 9c8b 2842 1617 9bb9 854d 5930 88d5 0279 ..(B.....MY0...y
0x0050: 94f4 1379 61cd 26c9 44b5 d9c7 d83b 783f ...ya.&.D....;x?
0x0060: b3ab b055 65d7 12bf 75f4 0ad8 32b4 bd33 ...Ue...u...2..3
0x0070: 412b eb5d 74a6 c019 56de 7a1c c7d7 e44c A+.]t...V.z....L
0x0080: 8f98 af79 ce12 681b 0132 a331 d76e 3cae ...y..h..2.1.n<.
0x0090: 303b 0095 cb32 fc02 087d c0e4 88b7 1c60 0;...2...}.....`
0x00a0: 8b15 00f3 bf22 f864 eacc 920b b912 4670 .....".d......Fp
0x00b0: 7ae8 f0a6 314b fd89 31a1 3683 521a 9464 z...1K..1.6.R..d
0x00c0: e974 cca8 96c5 3700 4138 17ff 2571 b125 .t....7.A8..%q.%
0x00d0: 721d aaec 0858 cc8f 6e82 9444 b3c4 7072 r....X..n..D..pr
0x00e0: 9b4f 4bbf 0837 eafc 8a1d 3da7 db49 4200 .OK..7....=..IB.
0x00f0: 35e4 6e29 031c 8eb7 40f4 fc41 c703 e00c 5.n)....@..A....
0x0100: 9b8c 5ace 3b5c deee 9f40 2661 8edb 25fb ..Z.;\...@&a..%.
0x0110: d0fa d00b fa9e 41bf 4b54 7161 8c22 7109 ......A.KTqa."q.
0x0120: 9e00 6691 9717 55e7 4d7c 3b90 75fe b3ce ..f...U.M|;.u...
0x0130: a759 6c86 0c91 2d71 4d9a e9c3 a360 bfb3 .Yl...-qM....`..
0x0140: 6b04 0568 0c26 04ab fcc8 6b24 28b1 k..h.&....k$(.
03:22:05.806236 unknown 802.11 ctrl frame subtype (5)
03:22:05.806261 unknown 802.11 ctrl frame subtype (0)
03:22:05.806437 unknown 802.11 frame type (3)
03:22:05.806760 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.808403 BA RA:fa:c4:92:c6:ab:dd
03:22:05.809887 unknown 802.11 frame type (3)
03:22:05.810088 unknown 802.11 ctrl frame subtype (5)
03:22:05.810500 Request-To-Send TA:a6:46:8d:1a:4d:12
03:22:05.810546 unknown 802.11 ctrl frame subtype (5)
03:22:05.810572 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.810613 unknown 802.11 ctrl frame subtype (5)
03:22:05.811113 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.811301 Beacon (DKT-Guest-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1
03:22:05.811339 Unhandled Management subtype(e)
03:22:05.811351 BA RA:a6:46:8d:1a:4d:12
03:22:05.811361 Unhandled Management subtype(e)
03:22:05.811517 BA RA:a6:46:8d:1a:4d:12
03:22:05.811625 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.813131 BA RA:fa:c4:92:c6:ab:dd
03:22:05.813154 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.813418 unknown 802.11 ctrl frame subtype (5)
03:22:05.813619 BA RA:fa:a4:a4:c6:ab:dd
03:22:05.813655 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.813665 Clear-To-Send RA:dc:37:14:cf:c9:53
03:22:05.813736 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.813800 BA RA:dc:37:14:cf:c9:53
03:22:05.814499 unknown 802.11 frame type (3)
03:22:05.816363 [|802.11]
03:22:05.816669 unknown 802.11 ctrl frame subtype (6)
03:22:05.816785 Beacon (DKT-Staff-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.817137 Data IV:7adf Pad 20 KeyID 0
03:22:05.817246 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.819727 Authentication (Open System)-2:
03:22:05.821161 unknown 802.11 ctrl frame subtype (5)
03:22:05.821295 Data IV:5d02 Pad 20 KeyID 1
03:22:05.821757 Action (c8:e2:dc:15:33:c4): Reserved(106) Act#50
03:22:05.824722 Authentication (Open System)-2:
03:22:05.825521 [|802.11]
03:22:05.825755 unknown 802.11 ctrl frame subtype (1)
03:22:05.826886 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.827282 Beacon (DKT-Staff-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.829187 Request-To-Send TA:a6:46:8d:1a:4d:12
03:22:05.829232 [|802.11]
03:22:05.829257 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.829268 unknown 802.11 ctrl frame subtype (5)
03:22:05.829777 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.829897 Unhandled Management subtype(e)
03:22:05.830010 Unhandled Management subtype(e)
03:22:05.830042 BA RA:a6:46:8d:1a:4d:12
03:22:05.830064 BA RA:a6:46:8d:1a:4d:12
03:22:05.830112 BA RA:a6:46:8d:1a:4d:12
03:22:05.830640 Authentication (Open System)-2:
03:22:05.831159 BA RA:a6:46:8d:1a:4d:12
03:22:05.831994 Beacon (Jguest) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 108
03:22:05.832448 Beacon (Jwifi) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 108, PRIVACY
03:22:05.832477 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.832510 Authentication (Open System)-2:
03:22:05.833197 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.833207 Clear-To-Send RA:dc:37:14:cf:c9:53
03:22:05.833230 BA RA:dc:37:14:cf:c9:53
03:22:05.833240 IP 192.168.148.58.137 > 192.168.159.255.137: UDP, length 50
03:22:05.833249 IP 192.168.132.9.137 > 192.168.159.255.137: UDP, length 50
03:22:05.833273 IP 192.168.153.136.137 > 192.168.159.255.137: UDP, length 50
03:22:05.834836 Data IV:7ae0 Pad 20 KeyID 0
03:22:05.836069 Probe Response (MFC-Agency) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] CH: 104
03:22:05.837089 Request-To-Send TA:a6:46:8d:1a:4d:12
03:22:05.837145 unknown 802.11 ctrl frame subtype (5)
03:22:05.837172 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.837206 unknown 802.11 ctrl frame subtype (5)
03:22:05.837693 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.837780 Unhandled Management subtype(e)
03:22:05.837896 Unhandled Management subtype(e)
03:22:05.837929 BA RA:a6:46:8d:1a:4d:12
03:22:05.839572 BA RA:a6:46:8d:1a:4d:12
03:22:05.839601 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.840271 BA RA:fa:c4:92:c6:ab:dd
03:22:05.840664 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.840698 BA RA:fa:c4:92:c6:ab:dd
03:22:05.840724 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.840743 Clear-To-Send RA:dc:37:14:cf:c9:53
03:22:05.840795 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.840835 BA RA:dc:37:14:cf:c9:53
03:22:05.842118 unknown 802.11 ctrl frame subtype (5)
03:22:05.842339 Authentication (Open System)-2:
03:22:05.842767 Data IV:7ae1 Pad 20 KeyID 0
03:22:05.842951 Unhandled Management subtype(e)
03:22:05.844495 Unhandled Management subtype(e)
03:22:05.844511 BA RA:a6:46:8d:1a:4d:12
03:22:05.845055 [|802.11]
03:22:05.845216 BA RA:a6:46:8d:1a:4d:12
03:22:05.845252 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.845262 Clear-To-Send RA:dc:37:14:cf:c9:53
03:22:05.845321 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.845385 BA RA:dc:37:14:cf:c9:53
03:22:05.847174 Data IV:7ae2 Pad 20 KeyID 0
03:22:05.851049 IP 192.168.153.136.137 > 192.168.159.255.137: UDP, length 50
03:22:05.851386 unknown 802.11 frame type (3)
03:22:05.852142 BA RA:82:83:1d:3b:46:8f
03:22:05.852563 Request-To-Send TA:a6:46:8d:1a:4d:12
03:22:05.852611 CF-End RA:ff:ff:ff:ff:ff:ff
03:22:05.852691 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.852707 unknown 802.11 ctrl frame subtype (5)
03:22:05.853263 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.853287 Unhandled Management subtype(e)
03:22:05.853542 Unhandled Management subtype(e)
03:22:05.853559 BA RA:a6:46:8d:1a:4d:12
03:22:05.853617 BA RA:a6:46:8d:1a:4d:12
03:22:05.853768 BA RA:a6:46:8d:1a:4d:12
03:22:05.853859 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.855282 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.855321 Unhandled Management subtype(e)
03:22:05.860761 BA RA:a6:46:8d:1a:4d:12
03:22:05.860784 BA RA:a6:46:8d:1a:4d:12
03:22:05.860796 BA RA:a6:46:8d:1a:4d:12
03:22:05.860806 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.860816 Data IV:7ae3 Pad 20 KeyID 0
03:22:05.860827 Data IV:7ae4 Pad 20 KeyID 0
03:22:05.860838 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.860849 Unhandled Management subtype(e)
03:22:05.860861 BA RA:a6:46:8d:1a:4d:12
03:22:05.860871 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.860886 Unhandled Management subtype(e)
03:22:05.861337 BA RA:a6:46:8d:1a:4d:12
03:22:05.861353 BA RA:a6:46:8d:1a:4d:12
03:22:05.861363 BA RA:a6:46:8d:1a:4d:12
03:22:05.861375 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.861385 Data IV:7ae5 Pad 20 KeyID 0
03:22:05.861395 Probe Request (Inchcape HK - SSO) [6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 Mbit]
03:22:05.861405 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.861415 Acknowledgment RA:7c:21:4a:37:e9:48
03:22:05.861425 Unhandled Management subtype(e)
03:22:05.861434 BA RA:a6:46:8d:1a:4d:12
03:22:05.861443 Beacon (MFC) [1.0* 2.0* 5.5* 11.0* 6.0 9.0 12.0 18.0 Mbit] ESS CH: 1
03:22:05.861693 Acknowledgment RA:a6:46:8d:1a:4d:12
03:22:05.862720 Beacon (DKT-Guest-WiFi) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 108
03:22:05.881620 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.881649 Unhandled Management subtype(e)
03:22:05.881662 BA RA:a6:46:8d:1a:4d:12
03:22:05.881672 BA RA:a6:46:8d:1a:4d:12
03:22:05.881683 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.881692 IP 192.168.132.9.137 > 192.168.159.255.137: UDP, length 50
03:22:05.881703 Beacon (DKT-Guest-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1
03:22:05.881713 IP 192.168.153.136.137 > 192.168.159.255.137: UDP, length 50
03:22:05.881724 unknown 802.11 ctrl frame subtype (5)
03:22:05.881734 Unhandled Management subtype(e)
03:22:05.881744 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.881755 Acknowledgment RA:42:34:57:12:4c:b1
03:22:05.881765 unknown 802.11 ctrl frame subtype (1)
03:22:05.881776 Clear-To-Send RA:fa:04:29:fe:ab:dd
03:22:05.881786 BA RA:fa:c4:92:c6:ab:dd
03:22:05.892144 Clear-To-Send RA:a8:5b:f7:2e:ea:90
03:22:05.892168 [|802.11]
03:22:05.892179 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.892190 Beacon (DKT-Staff-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.892200 Beacon (TWF) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 36, PRIVACY
03:22:05.892213 Data IV:daad Pad 20 KeyID 1
03:22:05.892223 BA RA:fa:c4:92:c6:ab:dd
03:22:05.892234 CF-End RA:ff:ff:ff:ff:ff:ff
03:22:05.892244 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.892254 BA RA:fa:c4:92:c6:ab:dd
03:22:05.892267 Probe Response (Inchcape HK - internal) [12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] CH: 36, PRIVACY
03:22:05.892277 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.892287 unknown 802.11 ctrl frame subtype (5)
03:22:05.892298 Probe Response (Inchcape HK - ilight) [12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] CH: 36, PRIVACY
03:22:05.904060 unknown 802.11 ctrl frame subtype (5)
03:22:05.904082 Probe Response (Inchcape HK - ilight) [12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] CH: 36, PRIVACY
03:22:05.904094 Probe Response (Inchcape HK - SSO) [12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] CH: 36, PRIVACY
03:22:05.904105 Probe Request (Inchcape HK - SSO) [6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 Mbit]
03:22:05.904117 Acknowledgment RA:a6:46:8d:1a:4d:12
03:22:05.904127 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.904137 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.904147 Acknowledgment RA:de:17:e3:72:fc:14
03:22:05.904157 Data IV:7ae6 Pad 20 KeyID 0
03:22:05.904168 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.904178 BA RA:fa:c4:92:c6:ab:dd
03:22:05.904189 Beacon (TWF-2.4G) [1.0* 2.0* 5.5* 11.0* 6.0 9.0 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.904199 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.904211 Unhandled Management subtype(e)
03:22:05.904223 BA RA:a6:46:8d:1a:4d:12
03:22:05.904233 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.904243 Data IV:7ae7 Pad 20 KeyID 0
03:22:05.904253 Data IV:7ae8 Pad 20 KeyID 0
03:22:05.904263 unknown 802.11 ctrl frame subtype (5)
03:22:05.904274 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.904285 Unhandled Management subtype(e)
03:22:05.904297 BA RA:a6:46:8d:1a:4d:12
03:22:05.904307 BA RA:a6:46:8d:1a:4d:12
03:22:05.904319 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.904329 BA RA:fa:c4:92:66:3a:a8
03:22:05.904338 unknown 802.11 ctrl frame subtype (5)
03:22:05.904349 Clear-To-Send RA:aa:46:8d:1a:4d:12
03:22:05.904359 Unhandled Management subtype(e)
03:22:05.904370 Unhandled Management subtype(e)
03:22:05.904384 Beacon (DKT-Guest-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1
03:22:05.904394 Beacon (VHService 5G) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS, PRIVACY
03:22:05.904404 BA RA:aa:46:8d:1a:4d:12
03:22:05.904415 unknown 802.11 ctrl frame subtype (0)
03:22:05.904425 unknown 802.11 ctrl frame subtype (5)
03:22:05.904435 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.904446 BA RA:fa:c4:92:c6:ab:dd
03:22:05.904456 [|802.11]
03:22:05.904467 Acknowledgment RA:64:76:ba:9a:8c:4c
03:22:05.904477 Request-To-Send TA:aa:46:8d:37:78:ea
03:22:05.904488 unknown 802.11 ctrl frame subtype (3)
03:22:05.904499 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.904511 BA RA:41:3c:93:c6:ab:dd
03:22:05.904521 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.904531 unknown 802.11 frame type (3)
03:22:05.904541 unknown 802.11 ctrl frame subtype (0)
03:22:05.904551 unknown 802.11 ctrl frame subtype (6)
03:22:05.904562 unknown 802.11 ctrl frame subtype (4)
03:22:05.904573 unknown 802.11 ctrl frame subtype (5)
03:22:05.904583 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.904594 Data IV:7ae9 Pad 20 KeyID 0
03:22:05.904605 unknown 802.11 ctrl frame subtype (5)
03:22:05.904614 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.904625 Data IV:7aea Pad 20 KeyID 0
03:22:05.904635 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.904645 [|802.11]
03:22:05.904655 BA RA:fa:c4:92:c6:ab:dd
03:22:05.904665 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.904675 BA RA:fa:c4:92:c6:ab:dd
03:22:05.928978 Authentication (Open System)-2:
03:22:05.928999 Unhandled Management subtype(e)
03:22:05.929012 Beacon () [11.0* 12.0 18.0 24.0 36.0 48.0 54.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.929024 Beacon () [11.0* 6.0 9.0 12.0 18.0 24.0 36.0 48.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.929035 BA RA:a6:46:8d:1a:4d:12
03:22:05.929046 Data IV:b71f Pad 20 KeyID 2
03:22:05.929057 Data IV:b720 Pad 20 KeyID 2
03:22:05.929070 Data IV:b722 Pad 20 KeyID 2
03:22:05.929080 unknown 802.11 ctrl frame subtype (5)
03:22:05.929090 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.929101 Data IV:b724 Pad 20 KeyID 2
03:22:05.929111 BA RA:fa:c4:92:c6:ab:dd
03:22:05.941739 unknown 802.11 ctrl frame subtype (5)
03:22:05.941760 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.941773 Data IV:7aeb Pad 20 KeyID 0
03:22:05.941784 [|802.11]
03:22:05.941794 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.941805 Data IV:7aec Pad 20 KeyID 0
03:22:05.941815 unknown 802.11 ctrl frame subtype (6)
03:22:05.941825 unknown 802.11 ctrl frame subtype (2)
03:22:05.941835 Acknowledgment RA:82:35:a3:21:5e:1f
03:22:05.941845 unknown 802.11 ctrl frame subtype (4)
03:22:05.941856 Data IV:b726 Pad 20 KeyID 2
03:22:05.941867 CF-End RA:ff:ff:ff:ff:ff:ff
03:22:05.941877 Assoc Response IV:5c0713 Pad 10 KeyID 0
03:22:05.941887 unknown 802.11 frame type (3)
03:22:05.941897 unknown 802.11 frame type (3)
03:22:05.941906 unknown 802.11 ctrl frame subtype (1)
03:22:05.941917 unknown 802.11 frame type (3)
03:22:05.941931 Beacon (DKT-Guest-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1
03:22:05.941941 [|802.11]
03:22:05.941953 Request-To-Send TA:76:a3:f1:9a:92:80
03:22:05.941963 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.941973 BA RA:fa:c4:92:c6:ab:dd
03:22:05.941983 unknown 802.11 ctrl frame subtype (5)
03:22:05.941992 Acknowledgment RA:27:57:80:59:06:59
03:22:05.942002 Request-To-Send TA:aa:46:8d:37:78:ea
03:22:05.942012 unknown 802.11 ctrl frame subtype (5)
03:22:05.942023 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.942032 unknown 802.11 frame type (3)
03:22:05.942042 BA RA:29:e7:ef:26:37:0c
03:22:05.942052 BA RA:fa:c4:92:c6:ab:dd
03:22:05.942063 [|802.11]
03:22:05.942072 Control Wrapper
03:22:05.942082 Acknowledgment RA:e6:15:bf:5b:ef:4e
03:22:05.942093 unknown 802.11 frame type (3)
03:22:05.942103 DeAuthentication IV:fab020 Pad 3f KeyID 0
03:22:05.942113 unknown 802.11 ctrl frame subtype (5)
03:22:05.942123 [|802.11]
03:22:05.942133 ReAssoc Response IV:af6355 Pad 2b KeyID 2
03:22:05.942145 unknown 802.11 ctrl frame subtype (5)
03:22:05.942154 Acknowledgment RA:10:d5:61:74:54:4f
03:22:05.942165 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.942175 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.942185 Authentication (Open System)-2:
03:22:05.942195 Unhandled Management subtype(e)
03:22:05.942206 BA RA:a6:46:8d:1a:4d:12
03:22:05.942217 BA RA:a6:46:8d:1a:4d:12
03:22:05.942228 CF-End RA:ff:ff:ff:4c:b4:ff
03:22:05.942239 Authentication (Open System)-2:
03:22:05.942249 Authentication (Open System)-2:
03:22:05.942259 unknown 802.11 frame type (3)
03:22:05.942269 Authentication (Open System)-2:
03:22:05.942278 Authentication (Open System)-2:
03:22:05.942288 Beacon (Jwifi) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 108, PRIVACY
03:22:05.942299 unknown 802.11 ctrl frame subtype (1)
03:22:05.942310 unknown 802.11 frame type (3)
03:22:05.942321 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.942331 Unhandled Management subtype(e)
03:22:05.942341 BA RA:a6:46:8d:1a:4d:12
03:22:05.942351 Authentication (Open System)-2:
03:22:05.942361 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.942371 Data IV:7aed Pad 20 KeyID 0
03:22:05.942381 unknown 802.11 ctrl frame subtype (4)
03:22:05.942391 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:05.942402 Data IV:7aee Pad 20 KeyID 0
03:22:05.942411 unknown 802.11 frame type (3)
03:22:05.946582 b8:7a:8d:ea:a2:52 Unknown SSAP 0xc8 > ff:ff:ff:ff:ff:c7 Unknown DSAP 0x44 Unnumbered, 67, Flags [Command], length 86
0x0000: 45c8 6771 beeb 85fc 9bf5 8439 19c8 65e7 E.gq.......9..e.
0x0010: f79c 50ab 1f13 ec4a 9478 240d 539c e741 ..P....J.x$.S..A
0x0020: aeab c9c9 9ea9 e701 6430 bf23 8f50 011c ........d0.#.P..
0x0030: 7489 6fec dc32 95a9 9de9 c304 fac5 361e t.o..2........6.
0x0040: 4177 d9c0 07a5 4143 418f b434 cc8f ae9f Aw....ACA..4....
0x0050: d039 41fb fcbf .9A...
03:22:05.946710 Request-To-Send TA:9f:4f:68:46:f2:61
03:22:05.948182 unknown 802.11 frame type (3)
03:22:05.948827 Beacon (TONE_S_2) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS, PRIVACY
03:22:05.949219 Unhandled Management subtype(f) IV:dee8cc Pad 0 KeyID 1
03:22:05.949789 Acknowledgment RA:34:e1:2d:62:6b:41
03:22:05.956195 Data IV:3ff9 Pad 20 KeyID 0
03:22:05.956219 Unhandled Management subtype(e)
03:22:05.956231 BA RA:a6:46:8d:1a:4d:12
03:22:05.956241 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.956251 Unhandled Management subtype(e)
03:22:05.978229 BA RA:a6:46:8d:1a:4d:12
03:22:05.978249 unknown 802.11 ctrl frame subtype (5)
03:22:05.978259 BA RA:40:b3:7a:ad:85:80
03:22:05.978271 Unhandled Management subtype(e)
03:22:05.978285 BA RA:a6:46:8d:1a:4d:12
03:22:05.978297 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.978307 Acknowledgment RA:10:d5:61:74:54:4f
03:22:05.978317 BA RA:fa:c4:92:c6:ab:dd
03:22:05.978327 Unhandled Management subtype(e)[|802.11]
03:22:05.978337 unknown 802.11 ctrl frame subtype (5)
03:22:05.980103 [|802.11]
03:22:05.980120 unknown 802.11 frame type (3)
03:22:05.980131 ATIM IV:25d645 Pad 35 KeyID 3
03:22:05.980141 unknown 802.11 ctrl frame subtype (2)
03:22:05.980151 Authentication (Open System)-2:
03:22:05.980161 Beacon (DKT-Guest-WiFi) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 108
03:22:05.980171 Beacon (MFC-Agency) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 108
03:22:05.980180 Beacon (DKT-Guest-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1
03:22:05.980191 IP 192.168.146.74.137 > 192.168.159.255.137: UDP, length 50
03:22:05.980202 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.980212 unknown 802.11 frame type (3)
03:22:05.980222 Probe Response (MFC-Agency) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] CH: 108
03:22:05.980233 Beacon (DKT-Staff-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.980243 [|802.11]
03:22:05.980253 Request-To-Send TA:ad:68:93:a2:af:8f
03:22:05.980262 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.980277 BA RA:fa:c4:92:c6:ab:dd
03:22:05.980287 unknown 802.11 frame type (3)
03:22:05.980296 unknown 802.11 ctrl frame subtype (5)
03:22:05.980305 BA RA:fa:c4:92:c6:ab:dd
03:22:05.980313 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.981227 BA RA:fa:c4:92:c6:ab:dd
03:22:05.984191 unknown 802.11 ctrl frame subtype (5)
03:22:05.984302 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.985226 BA RA:fa:c4:92:c6:ab:dd
03:22:05.986012 Beacon (MFC) [1.0* 2.0* 5.5* 11.0* 6.0 9.0 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.986811 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.986830 BA RA:fa:c4:92:c6:ab:dd
03:22:05.986920 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.987191 BA RA:fa:c4:92:c6:ab:dd
03:22:05.987985 Beacon (VHService 5G) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS, PRIVACY
03:22:05.988375 BA RA:58:76:45:c3:8c:da
03:22:05.988629 Acknowledgment RA:16:17:b7:4d:77:ba
03:22:05.988786 Request-To-Send TA:20:e5:2a:0c:2c:31
03:22:05.988820 Clear-To-Send RA:20:e5:2a:0c:2c:31
03:22:05.988944 BA RA:20:e5:2a:0c:2c:31
03:22:05.993150 unknown 802.11 ctrl frame subtype (5)
03:22:05.993169 [|802.11]
03:22:05.993183 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:05.993193 Request-To-Send TA:16:17:b7:4d:77:ba
03:22:05.993202 Clear-To-Send RA:16:17:b7:4d:77:ba
03:22:05.993213 BA RA:16:17:b7:4d:77:ba
03:22:05.997365 unknown 802.11 ctrl frame subtype (5)
03:22:05.998007 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:05.998679 BA RA:fa:c4:92:c6:ab:dd
03:22:05.998929 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:05.999666 Unhandled Management subtype(e)
03:22:05.999915 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:06.000102 Unhandled Management subtype(e)
03:22:06.003027 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:06.003050 BA RA:a6:46:8d:1a:4d:12
03:22:06.003061 Unhandled Management subtype(e)
03:22:06.003071 BA RA:a6:46:8d:1a:4d:12
03:22:06.003081 BA RA:fa:c4:92:c6:ab:dd
03:22:06.003360 Beacon (DKT-Staff-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:06.003498 Beacon () [11.0* 12.0 18.0 24.0 36.0 48.0 54.0 Mbit] ESS CH: 1, PRIVACY
03:22:06.003815 unknown 802.11 ctrl frame subtype (5)
03:22:06.015073 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:06.015104 Beacon () [11.0* 6.0 9.0 12.0 18.0 24.0 36.0 48.0 Mbit] ESS CH: 1, PRIVACY
03:22:06.015118 Data IV:7aef Pad 20 KeyID 0
03:22:06.015129 Data IV:7af0 Pad 20 KeyID 0
03:22:06.015139 Data IV:7af1 Pad 20 KeyID 0
03:22:06.015149 Data IV:b729 Pad 20 KeyID 2
03:22:06.015160 Data IV:b72a Pad 20 KeyID 2
03:22:06.015171 Data IV:b72c Pad 20 KeyID 2
03:22:06.018011 unknown 802.11 ctrl frame subtype (5)
03:22:06.018031 Data IV:b72e Pad 20 KeyID 2
03:22:06.018043 Data IV:b730 Pad 20 KeyID 2
03:22:06.018053 unknown 802.11 ctrl frame subtype (0)
03:22:06.018063 Data IV:b732 Pad 20 KeyID 2
03:22:06.018073 Data IV:b734 Pad 20 KeyID 2
03:22:06.018083 Clear-To-Send RA:12:e6:93:c6:2b:2a
03:22:06.018093 BA RA:fa:c4:92:c6:ab:dd
03:22:06.018596 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:06.018609 Data IV:b736 Pad 20 KeyID 2
03:22:06.018621 BA RA:fa:c4:92:c6:75:80
03:22:06.018631 unknown 802.11 ctrl frame subtype (5)
03:22:06.018644 CF-End RA:ff:ff:ff:ff:ff:ff
03:22:06.018654 unknown 802.11 ctrl frame subtype (5)
03:22:06.018665 Disassociation: Reserved
03:22:06.018674 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:06.018685 Data IV:b738 Pad 20 KeyID 2
03:22:06.018694 BA RA:fa:c4:92:c6:ab:dd
03:22:06.018705 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:06.018714 BA RA:fa:c4:92:c6:ab:dd
03:22:06.018724 Beacon (DKT-Guest-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1
03:22:06.018966 unknown 802.11 ctrl frame subtype (5)
03:22:06.019186 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:06.030415 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:06.030435 BA RA:fa:c4:92:c6:ab:dd
03:22:06.030445 unknown 802.11 ctrl frame subtype (5)
03:22:06.030455 unknown 802.11 ctrl frame subtype (5)
03:22:06.030465 unknown 802.11 ctrl frame subtype (5)
03:22:06.030475 unknown 802.11 ctrl frame subtype (5)
03:22:06.030485 Unhandled Management subtype(e)
03:22:06.030497 Beacon (DKT-Staff-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:06.030507 BA RA:d0:15:a6:c9:ec:30
03:22:06.030517 Request-To-Send TA:2e:72:38:0e:85:04
03:22:06.031822 unknown 802.11 ctrl frame subtype (5)
03:22:06.032027 Power Save-Poll AID(ff1c)
03:22:06.033051 CF-End RA:ff:ff:ff:ff:ff:ff
03:22:06.033623 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:06.033752 Unhandled Management subtype(e)
03:22:06.040086 BA RA:a6:46:8d:1a:4d:12
03:22:06.040106 BA RA:a6:46:8d:1a:4d:12
03:22:06.040120 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:06.040130 Unhandled Management subtype(e)
03:22:06.040141 BA RA:a6:46:8d:1a:4d:12
03:22:06.040151 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:06.040161 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:06.040170 Data IV:7af2 Pad 20 KeyID 0
03:22:06.040181 Beacon (Jmeeting) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 108[|802.11]
03:22:06.040190 Unhandled Management subtype(e)
03:22:06.052365 BA RA:a6:46:8d:1a:4d:12
03:22:06.052392 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:06.052403 Data IV:7af3 Pad 20 KeyID 0
03:22:06.052414 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:06.052426 Unhandled Management subtype(e)
03:22:06.052437 BA RA:a6:46:8d:1a:4d:12
03:22:06.052448 BA RA:a6:46:8d:1a:4d:12
03:22:06.052459 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:06.052470 BA RA:fa:c4:92:c6:ab:dd
03:22:06.052480 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:06.052490 Data IV:7af4 Pad 20 KeyID 0
03:22:06.052502 Data IV:7af5 Pad 20 KeyID 0
03:22:06.052513 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:06.052523 BA RA:fa:c4:92:c6:ab:dd
03:22:06.056261 unknown 802.11 ctrl frame subtype (5)
03:22:06.056283 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:06.056295 Unhandled Management subtype(e)
03:22:06.056307 BA RA:a6:46:8d:1a:4d:12
03:22:06.056317 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:06.056327 BA RA:fa:c4:92:c6:ab:dd
03:22:06.056339 ATIM IV:f9c82 Pad 3c KeyID 1
03:22:06.056348 unknown 802.11 ctrl frame subtype (5)
03:22:06.056359 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:06.056370 Unhandled Management subtype(e)
03:22:06.056380 BA RA:a6:46:8d:1a:4d:12
03:22:06.056390 BA RA:a6:46:8d:1a:4d:12
03:22:06.056401 Acknowledgment RA:16:17:b7:4d:77:ba
03:22:06.056410 BA RA:a6:46:8d:1a:4d:12
03:22:06.056421 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:06.056431 Unhandled Management subtype(e)
03:22:06.056445 BA RA:a6:46:8d:1a:4d:12
03:22:06.056455 BA RA:a6:46:8d:1a:4d:12
03:22:06.056465 BA RA:a6:46:8d:1a:4d:12
03:22:06.056477 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:06.056487 Data IV:7af6 Pad 20 KeyID 0
03:22:06.056496 Data IV:7af7 Pad 20 KeyID 0
03:22:06.056506 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:06.056517 Unhandled Management subtype(e)
03:22:06.056527 BA RA:a6:46:8d:1a:4d:12
03:22:06.056536 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:06.056545 Data IV:7af8 Pad 20 KeyID 0
03:22:06.056555 Data IV:7af9 Pad 20 KeyID 0
03:22:06.056565 Data IV:7afa Pad 20 KeyID 0
03:22:06.067305 Data IV:7afb Pad 20 KeyID 0
03:22:06.067325 Action IV:8db74d Pad 2a KeyID 0
03:22:06.067336 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:06.067347 Unhandled Management subtype(e)
03:22:06.067357 Beacon (DKT-GuM-%^_t-7/M-^Nj) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1[|802.11]
03:22:06.067368 BA RA:a6:46:8d:1a:4d:12
03:22:06.067377 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:06.067387 Data IV:7afc Pad 20 KeyID 0
03:22:06.067398 Data IV:7afd Pad 20 KeyID 0
03:22:06.067409 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:06.067418 Unhandled Management subtype(e)
03:22:06.067427 BA RA:a6:46:8d:1a:4d:12
03:22:06.067439 unknown 802.11 ctrl frame subtype (5)
03:22:06.078890 Acknowledgment RA:42:34:57:12:4c:b1
03:22:06.078912 Beacon (DKT-Guest-WiFi) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 108
03:22:06.078924 unknown 802.11 ctrl frame subtype (6)
03:22:06.078934 Beacon (MFC-Agency) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 108
03:22:06.078945 Clear-To-Send RA:7e:b3:fa:b9:b3:cb
03:22:06.078957 BA RA:7e:b3:fa:b9:b3:cb
03:22:06.078967 Beacon (DKT-Guest-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1
03:22:06.078977 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:06.078989 Unhandled Management subtype(e)
03:22:06.078999 BA RA:a6:46:8d:1a:4d:12
03:22:06.079010 unknown 802.11 ctrl frame subtype (3)
03:22:06.079020 Clear-To-Send RA:7e:b3:fa:b9:b3:cb
03:22:06.079031 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:06.079041 BA RA:7e:b3:fa:b9:b3:cb
03:22:06.079051 Probe Response (MFC) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] CH: 1
03:22:06.079063 Beacon (GELEC_STAFF) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 48
03:22:06.079075 [|802.11]
03:22:06.079083 Probe Response (MFC) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] CH: 1
03:22:06.079190 unknown 802.11 ctrl frame subtype (5)
03:22:06.080813 Probe Request IV:cf928b Pad 14 KeyID 3
03:22:06.081795 Beacon (TWF-2.4G) [1.0* 2.0* 5.5* 11.0* 6.0 9.0 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:06.082278 unknown 802.11 ctrl frame subtype (5)
03:22:06.082385 Unhandled Management subtype(e)
03:22:06.082707 BA RA:a6:46:8d:1a:4d:12
03:22:06.083793 BA RA:00:f8:7a:15:b4:3a
03:22:06.084155 [|802.11]
03:22:06.085107 Beacon (Inchcape HK - internal) [12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 48, PRIVACY
03:22:06.085373 Beacon (Inchcape HK - ilight) [12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 48, PRIVACY
03:22:06.089745 Beacon (Inchcape HK - SSO) [12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 48, PRIVACY
03:22:06.089765 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:06.089775 BA RA:fa:c4:92:c6:ab:dd
03:22:06.089786 Beacon () [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 48, PRIVACY
03:22:06.089797 Data IV:5b18 Pad 20 KeyID 2
03:22:06.089807 Data IV:5b19 Pad 20 KeyID 2
03:22:06.089817 Data IV:5b1b Pad 20 KeyID 2
03:22:06.089827 Probe Request () [1.0* 2.0* 5.5* 11.0* Mbit]
03:22:06.089836 unknown 802.11 ctrl frame subtype (5)
03:22:06.089845 unknown 802.11 ctrl frame subtype (5)
03:22:06.094418 [|802.11]
03:22:06.094437 BA RA:fa:c4:92:c6:ab:dd
03:22:06.094447 Request-To-Send TA:38:68:93:a2:af:8f
03:22:06.094457 BA RA:fa:c4:92:c6:ab:dd
03:22:06.094466 Request-To-Send TA:ab:46:8d:37:78:ea
03:22:06.094474 unknown 802.11 ctrl frame subtype (5)
03:22:06.094483 Request-To-Send TA:aa:46:8d:37:78:ea
03:22:06.094493 unknown 802.11 ctrl frame subtype (5)
03:22:06.095380 Acknowledgment RA:42:34:57:12:4c:b1
03:22:06.095486 Request-To-Send TA:86:07:2f:85:bf:96
03:22:06.095797 Data IV:924f Pad 0 KeyID 0
03:22:06.097415 Acknowledgment RA:a6:46:9d:1a:4d:12
03:22:06.100327 Unhandled Management subtype(e)
03:22:06.100491 BA RA:a6:46:8d:1a:4d:12
03:22:06.101838 Probe Response (Inchcape HK - SSO) [11.0* 12.0 18.0 24.0 36.0 48.0 54.0 Mbit] CH: 1, PRIVACY
03:22:06.102340 unknown 802.11 ctrl frame subtype (2)
03:22:06.102365 Request-To-Send TA:fd:87:97:a2:af:8f
03:22:06.102571 CF-End+CF-Ack RA:b9:b6:3e:13:4d:49
03:22:06.102753 Request-To-Send TA:83:7b:93:a2:49:8b
03:22:06.102840 Probe Response (TWF-2.4G) [1.0* 2.0* 5.5* 11.0* 6.0 9.0 12.0 18.0 Mbit] CH: 1, PRIVACY
03:22:06.102874 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:06.103511 Data IV:7afe Pad 20 KeyID 0
03:22:06.103525 Data IV:7aff Pad 20 KeyID 0
03:22:06.103763 Request-To-Send TA:4e:3c:ff:9a:9b:64
03:22:06.103807 Probe Response (Inchcape HK - SSO) [11.0* 12.0 18.0 24.0 36.0 48.0 54.0 Mbit] CH: 1, PRIVACY
03:22:06.103936 Data IV:b20f Pad 0 KeyID 0
03:22:06.105621 Probe Response (Inchcape HK - SSO) [11.0* 12.0 18.0 24.0 36.0 48.0 54.0 Mbit] CH: 1, PRIVACY
03:22:06.107036 Data IV:b20f Pad 0 KeyID 0
03:22:06.107140 [|802.11]
03:22:06.108266 Beacon () [11.0* 12.0 18.0 24.0 36.0 48.0 54.0 Mbit] ESS CH: 1, PRIVACY
03:22:06.108702 BAR RA:95:58:75:34:88:71 TA:bd:de:31:40:96:8a CTL(64db) SEQ(7037)
03:22:06.110139 [|802.11]
03:22:06.110308 Probe Request () [1.0* 2.0* 5.5* 11.0* Mbit]
03:22:06.110795 CF-End RA:ff:ff:ff:ff:ff:ff
03:22:06.112023 Request-To-Send TA:38:8e:34:33:bc:69
03:22:06.113636 unknown 802.11 ctrl frame subtype (2)
03:22:06.115303 Acknowledgment RA:a6:46:9d:1a:4d:12
03:22:06.115669 Data IV:b73d Pad 20 KeyID 2
03:22:06.116677 Data IV:b73e Pad 20 KeyID 2
03:22:06.117786 Probe Response (Inchcape HK - SSO) [11.0* 12.0 18.0 24.0 36.0 48.0 54.0 Mbit] CH: 1, PRIVACY
03:22:06.118506 unknown 802.11 ctrl frame subtype (5)
03:22:06.118616 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:06.122637 Probe Response (TWF-2.4G) [1.0* 2.0* 5.5* 11.0* 6.0 9.0 12.0 18.0 Mbit] CH: 1, PRIVACY
03:22:06.123279 BA RA:fa:c4:92:c6:ab:dd
03:22:06.124385 unknown 802.11 ctrl frame subtype (5)
03:22:06.129336 Control Wrapper
03:22:06.130639 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:06.131635 Data IV:c125 Pad 20 KeyID 2
03:22:06.132682 CF-End RA:ff:ff:ff:ff:ff:ff
03:22:06.132704 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:06.132713 Unhandled Management subtype(e)
03:22:06.133178 Probe Response (Inchcape HK - internal) [12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] CH: 48, PRIVACY
03:22:06.133586 Probe Response (Inchcape HK - ilight) [12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] CH: 48, PRIVACY
03:22:06.134075 Probe Response (Inchcape HK - SSO) [12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] CH: 48, PRIVACY
03:22:06.134128 BA RA:a6:46:8d:1a:4d:12
03:22:06.134229 Unhandled Management subtype(e)
03:22:06.135654 BA RA:a6:46:8d:1a:4d:12
03:22:06.135679 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:06.136626 BA RA:f8:c4:92:c6:ab:dd
03:22:06.136781 Unhandled Management subtype(e)
03:22:06.137246 BA RA:a6:46:8d:1a:4d:12
03:22:06.138054 Beacon (MFC-Agency) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 108[|802.11]
03:22:06.138088 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:06.138196 Unhandled Management subtype(e)
03:22:06.138765 BA RA:a6:46:8d:1a:4d:12
03:22:06.138954 Beacon (Jmeeting) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 108
03:22:06.139100 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:06.140896 Data IV:7b00 Pad 20 KeyID 0
03:22:06.140910 Data IV:7b01 Pad 20 KeyID 0
03:22:06.141892 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:06.141916 BA RA:fa:c4:92:c6:ab:dd
03:22:06.142590 [|802.11]
03:22:06.142729 Unhandled Management subtype(e)
03:22:06.143607 BA RA:a6:46:8d:1a:4d:12
03:22:06.144614 unknown 802.11 ctrl frame subtype (5)
03:22:06.144794 Acknowledgment RA:4e:bf:70:8f:e1:fb
03:22:06.144907 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:06.145814 Data IV:7b02 Pad 20 KeyID 0
03:22:06.145891 Clear-To-Send RA:bd:38:bf:21:b4:af
03:22:06.147007 Beacon () [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 48, PRIVACY
03:22:06.149402 Acknowledgment RA:2c:6d:c1:46:1b:e8
03:22:06.149813 unknown 802.11 ctrl frame subtype (5)
03:22:06.150704 Power Save-Poll AID(e808)
03:22:06.150814 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:06.153492 BA RA:fa:c4:92:c6:ab:dd
03:22:06.153768 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:06.153999 Unhandled Management subtype(e)
03:22:06.155989 BA RA:a6:46:8d:1a:4d:12
03:22:06.156085 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:06.156234 Data IV:7b03 Pad 20 KeyID 0
03:22:06.157223 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:06.157735 BA RA:fa:c4:92:4a:2f:97
03:22:06.159244 unknown 802.11 ctrl frame subtype (5)
03:22:06.159262 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:06.159375 Unhandled Management subtype(e)
03:22:06.159961 BA RA:a6:46:8d:1a:4d:12
03:22:06.161903 Clear-To-Send RA:aa:46:8d:37:7a:14
03:22:06.162013 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:06.162787 Beacon (MFC) [1.0* 2.0* 5.5* 11.0* 6.0 9.0 12.0 18.0 Mbit] ESS CH: 1
03:22:06.162915 BA RA:fa:c4:92:c6:ab:dd
03:22:06.162943 Acknowledgment RA:4e:bf:70:8f:21:e7
03:22:06.163026 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:06.164168 BA RA:fa:c4:92:c6:ab:dd
03:22:06.164506 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:06.164695 Unhandled Management subtype(e)
03:22:06.164990 BA RA:a6:46:8d:1a:4d:12
03:22:06.165375 unknown 802.11 ctrl frame subtype (5)
03:22:06.166532 Acknowledgment RA:42:34:57:12:4c:b1
03:22:06.166555 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:06.166896 BA RA:fa:c4:92:c6:ab:dd
03:22:06.170593 Beacon (DKT-Guest-WiFi) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 108
03:22:06.171522 unknown 802.11 ctrl frame subtype (1)
03:22:06.171632 Beacon (MFC-Agency) [6.0* 9.0 12.0* 18.0 24.0* 36.0 48.0 54.0 Mbit] ESS CH: 108
03:22:06.171945 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:06.172824 BA RA:fa:c4:92:c6:ab:dd
03:22:06.172902 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:06.173062 Beacon (DKT-Guest-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1
03:22:06.173688 BA RA:fa:c4:92:c6:ab:dd
03:22:06.174734 Clear-To-Send RA:aa:46:8d:37:7a:14
03:22:06.174848 Unhandled Management subtype(e)
03:22:06.175240 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:06.176637 BA RA:a6:46:8d:1a:4d:12
03:22:06.177317 Beacon (DKT-Staff-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:06.179643 unknown 802.11 ctrl frame subtype (5)
03:22:06.179708 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:06.180441 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:06.180811 Clear-To-Send RA:fb:8b:69:e3:2a:15
03:22:06.180855 Beacon (TWF-2.4G) [1.0* 2.0* 5.5* 11.0* 6.0 9.0 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:06.181208 Acknowledgment RA:10:d5:61:3d:04:ad
03:22:06.182751 Clear-To-Send RA:84:5c:f3:fd:25:82
03:22:06.182763 [|802.11]
03:22:06.182958 unknown 802.11 frame type (3)
03:22:06.183845 Assoc Request IV:7a431a Pad d KeyID 2
03:22:06.183943 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:06.184153 BA RA:fa:c4:92:c6:ab:dd
03:22:06.184985 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:06.185116 Unhandled Management subtype(e)
03:22:06.185934 BA RA:a6:46:8d:1a:4d:12
03:22:06.186767 Data IV:61cd Pad 20 KeyID 0
03:22:06.186778 Data IV:61ce Pad 20 KeyID 0
03:22:06.186789 Data IV:61cf Pad 20 KeyID 0
03:22:06.186799 Data IV:61d0 Pad 20 KeyID 0
03:22:06.186808 Data IV:61d1 Pad 20 KeyID 0
03:22:06.186817 Data IV:61d2 Pad 20 KeyID 0
03:22:06.186834 Data IV:61d3 Pad 20 KeyID 0
03:22:06.186846 Data IV:61d4 Pad 20 KeyID 0
03:22:06.186887 BA RA:48:5f:99:43:cf:bb
03:22:06.186954 unknown 802.11 ctrl frame subtype (5)
03:22:06.187250 Request-To-Send TA:86:07:2f:85:bf:96
03:22:06.187276 Data IV:61c3 Pad 20 KeyID 0
03:22:06.190862 Beacon (MFC) [1.0* 2.0* 5.5* 11.0* 6.0 9.0 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:06.191168 BA RA:48:5f:99:43:cf:bb
03:22:06.192497 Data IV:904f Pad 0 KeyID 0
03:22:06.192557 Beacon (DKT-Guest-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1
03:22:06.193652 Data IV:61cd Pad 20 KeyID 0
03:22:06.193665 Data IV:61ce Pad 20 KeyID 0
03:22:06.193675 Data IV:61cf Pad 20 KeyID 0
03:22:06.193685 Data IV:61d0 Pad 20 KeyID 0
03:22:06.193695 Data IV:61d1 Pad 20 KeyID 0
03:22:06.193707 Data IV:61d2 Pad 20 KeyID 0
03:22:06.193717 Data IV:61d3 Pad 20 KeyID 0
03:22:06.193725 Data IV:61d4 Pad 20 KeyID 0
03:22:06.193759 BA RA:48:5f:99:43:cf:bb
03:22:06.193810 unknown 802.11 ctrl frame subtype (5)
03:22:06.193843 Request-To-Send TA:aa:46:8d:1a:4f:9d
03:22:06.193933 unknown 802.11 ctrl frame subtype (5)
03:22:06.194734 Beacon () [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:06.195402 Beacon (DKT-Staff-WiFi) [1.0* 2.0* 5.5* 6.0 9.0 11.0* 12.0 18.0 Mbit] ESS CH: 1, PRIVACY
03:22:06.198277 Data IV:61c3 Pad 20 KeyID 0
03:22:06.198294 Data IV:61c4 Pad 20 KeyID 0
03:22:06.198305 Data IV:61c5 Pad 20 KeyID 0
03:22:06.198315 Data IV:61c6 Pad 20 KeyID 0
03:22:06.200515 Acknowledgment RA:42:34:57:12:4c:b1
03:22:06.200675 Unhandled Management subtype(e)
03:22:06.201222 BA RA:48:5f:99:43:cf:bb
03:22:06.202005 BA RA:a6:46:8d:1a:4d:12
03:22:06.202971 unknown 802.11 ctrl frame subtype (6)
03:22:06.203085 Request-To-Send TA:dc:37:14:cf:c9:53
03:22:06.203713 Data IV:7b04 Pad 20 KeyID 0
03:22:06.203726 Data IV:7b05 Pad 20 KeyID 0
03:22:06.203758 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:06.205075 BA RA:fa:c4:92:c6:ab:dd
03:22:06.205147 Data IV:61c3 Pad 20 KeyID 0
03:22:06.205157 Data IV:61c4 Pad 20 KeyID 0
03:22:06.205167 Data IV:61c5 Pad 20 KeyID 0
03:22:06.207062 Data IV:61c6 Pad 20 KeyID 0
03:22:06.207079 Data IV:61c7 Pad 20 KeyID 0
03:22:06.207090 Data IV:61c8 Pad 20 KeyID 0
03:22:06.207100 Data IV:61c9 Pad 20 KeyID 0
03:22:06.207113 Data IV:61ca Pad 20 KeyID 0
03:22:06.207123 Data IV:61cb Pad 20 KeyID 0
03:22:06.207133 Data IV:61cc Pad 20 KeyID 0
03:22:06.207143 BA RA:48:5f:99:43:cf:bb
03:22:06.207152 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:06.207161 Clear-To-Send RA:84:5c:f3:fd:25:82
03:22:06.207170 BA RA:15:fe:92:c6:ab:dd
03:22:06.207179 Probe Response IV:a1e9d7 Pad 2b KeyID 2
03:22:06.207189 Request-To-Send TA:aa:46:8d:1a:4f:9d
03:22:06.207197 Clear-To-Send RA:aa:46:8d:1a:4f:9d
03:22:06.207206 unknown 802.11 frame type (3)
03:22:06.207216 BA RA:aa:46:8d:1a:4f:9d
03:22:06.207303 Clear-To-Send RA:aa:46:8d:1a:4f:9d
03:22:06.207314 unknown 802.11 ctrl frame subtype (5)
03:22:06.207485 BA RA:76:fb:19:52:70:12
03:22:06.207744 unknown 802.11 frame type (3)
03:22:06.207949 unknown 802.11 ctrl frame subtype (0)
03:22:06.208149 [|802.11]
03:22:06.210062 unknown 802.11 ctrl frame subtype (5)
03:22:06.210848 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:06.210874 BA RA:fa:c4:92:c6:ab:dd
03:22:06.211056 Data IV:61cd Pad 20 KeyID 0
03:22:06.211066 Data IV:61ce Pad 20 KeyID 0
03:22:06.211082 Data IV:61cf Pad 20 KeyID 0
03:22:06.220080 Data IV:61d0 Pad 20 KeyID 0
03:22:06.220100 Data IV:61d1 Pad 20 KeyID 0
03:22:06.220111 Data IV:61d2 Pad 20 KeyID 0
03:22:06.220121 Data IV:61d3 Pad 20 KeyID 0
03:22:06.220135 Data IV:61d4 Pad 20 KeyID 0
03:22:06.220144 CF-End+CF-Ack RA:97:1a:d4:c5:9d:2d
03:22:06.220154 Request-To-Send TA:ab:46:8d:1a:4f:9d
03:22:06.220165 unknown 802.11 ctrl frame subtype (5)
03:22:06.220175 CF-End RA:ff:ff:ff:ff:ff:ff
03:22:06.220185 Probe Request IV:f700b Pad 9 KeyID 1
03:22:06.220194 Probe Response (TWF-2.4G) [1.0* 2.0* 5.5* 11.0* 6.0 9.0 12.0 18.0 Mbit] CH: 1, PRIVACY
03:22:06.220204 Data IV:b741 Pad 20 KeyID 2
03:22:06.220214 [|802.11]
03:22:06.220223 Data IV:b742 Pad 20 KeyID 2
03:22:06.220237 Data IV:b744 Pad 20 KeyID 2
03:22:06.220246 unknown 802.11 ctrl frame subtype (5)
03:22:06.220256 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:06.220266 Data IV:b746 Pad 20 KeyID 2
03:22:06.220277 BA RA:fa:c4:92:c6:ab:dd
03:22:06.220287 Data IV:b748 Pad 20 KeyID 2
03:22:06.220296 unknown 802.11 ctrl frame subtype (5)
03:22:06.220306 Data IV:61c3 Pad 20 KeyID 0
03:22:06.220315 Data IV:61c4 Pad 20 KeyID 0
03:22:06.220325 Data IV:61c5 Pad 20 KeyID 0
03:22:06.220334 Data IV:61c6 Pad 20 KeyID 0
03:22:06.220345 Data IV:61c7 Pad 20 KeyID 0
03:22:06.220355 Data IV:61c8 Pad 20 KeyID 0
03:22:06.220366 Data IV:61c9 Pad 20 KeyID 0
03:22:06.220377 Data IV:61ca Pad 20 KeyID 0
03:22:06.220387 Data IV:61cb Pad 20 KeyID 0
03:22:06.220396 Data IV:61cc Pad 20 KeyID 0
03:22:06.229272 BA RA:48:5f:99:43:cf:bb
03:22:06.229294 unknown 802.11 ctrl frame subtype (5)
03:22:06.229305 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:06.229316 Data IV:b74a Pad 20 KeyID 2
03:22:06.229327 BA RA:fa:c4:92:c6:ab:dd
03:22:06.229336 Clear-To-Send RA:fa:c4:92:c6:ab:dd
03:22:06.229347 Data IV:61cd Pad 20 KeyID 0
03:22:06.229360 Data IV:61ce Pad 20 KeyID 0
03:22:06.229371 Data IV:61cf Pad 20 KeyID 0
03:22:06.229385 Data IV:61d0 Pad 20 KeyID 0
03:22:06.229396 Data IV:61d1 Pad 20 KeyID 0
03:22:06.229406 Data IV:61d2 Pad 20 KeyID 0
03:22:06.229417 Data IV:61d3 Pad 20 KeyID 0
03:22:06.245370 Data IV:61d4 Pad 20 KeyID 0
03:22:06.245390 BA RA:48:5f:99:43:cf:bb
03:22:06.245400 Clear-To-Send RA:84:5c:f3:fd:25:82
03:22:06.245411 BA RA:fa:c4:92:c6:ab:dd
03:22:06.245422 unknown 802.11 ctrl frame subtype (5)
03:22:06.245432 e8:34:2e:32:34:28 Unknown SSAP 0x2a > 00:c0:df:28:01:60 Unknown DSAP 0x34 Information, send seq 20, rcv seq 35, Flags [Final], length 28
0x0000: 342b 2847 6033 3e24 2c38 3d2a 342b 2a3a 4+(G`3>$,8=*4+*:
0x0010: 402e 3b28 0800 f8bb 0000 d007 @.;(........
03:22:06.245442 Request-To-Send TA:aa:46:8d:1a:4f:9d
03:22:06.245453 Clear-To-Send RA:aa:46:8d:1a:4f:9d
03:22:06.245462 unknown 802.11 ctrl frame subtype (5)
03:22:06.245473 Clear-To-Send RA:a6:46:8d:1a:4d:12
03:22:06.245483 Unhandled Management subtype(e)
03:22:06.245494 ac:34:0c:0c:13:1f Unknown SSAP 0x12 > 00:40:64:1f:01:3b Unknown DSAP 0x18 Information, send seq 12, rcv seq 18, Flags [Response], length 1644
0x0000: 1813 1824 3b00 180c 1f18 1c1f 1822 1f1c ...$;........"..
0x0010: 1818 1c18 8800 fbbb 0000 6322 4b44 e850 ..........c"KD.P
0x0020: 000c 1300 0013 1800 0c00 1318 1300 1324 ...............$
0x0030: 0026 2f26 241c 1c1f 3135 1c26 1c2b 3500 .&/&$...15.&.+5.
0x0040: 2426 2428 2a13 1f22 2a1f 2622 1c0c 220c $&$(*.."*.&"..".
0x0050: 0022 1c13 1813 0c2a 2626 281f 2428 282a .".....*&&(.$((*
0x0060: 4422 3222 0026 1818 1826 0c0c 2b22 2224 D"2".&...&..+""$
0x0070: 130c 1c00 2a2c 2a18 2836 2224 1800 2222 ....*,*.(6"$..""
0x0080: 2c2f 2c2c 2c39 2622 0c1c 1c28 0c2b 1f22 ,/,,,9&"...(.+."
0x0090: 2b1f 1318 1313 0c00 1818 180c 0000 0c00 +...............
0x00a0: 8800 fbbb 0000 6322 5542 ec50 0013 0000 ......c"UB.P....
0x00b0: 0000 1c18 2600 0022 0013 241c 2b22 2a24 ....&.."..$.+"*$
0x00c0: 301f 2618 1c0c 381f 342b 282b 2824 2618 0.&...8.4+(+($&.
0x00d0: 2200 132c 181c 1c2b 1c28 221f 1326 2218 "..,...+.("..&".
0x00e0: 2224 2b2a 2430 2628 2213 2c26 4232 242b "$+*$0&(".,&B2$+
0x00f0: 1c1f 1828 2813 1c1c 241f 2b28 2218 2e1c ...((...$.+("...
0x0100: 2232 2618 240c 2218 2c31 1f1c 2a2a 2828 "2&.$.".,1..**((
0x0110: 2232 1800 222a 1831 2c0c 2800 1c2a 0013 "2.."*.1,.(..*..
0x0120: 1813 1813 131c 1f0c 000c 1300 8800 fbbb ................
0x0130: 0000 6322 5543 ec4c 0c00 130c 0000 2200 ..c"UC.L......".
0x0140: 000c 0018 2200 181f 181f 1c2c 262a 322e ...."......,&*2.
0x0150: 3530 281c 341c 2f2b 2c28 1c2c 262c 2400 50(.4./+,(.,&,$.
0x0160: 241f 1f13 1324 261f 1318 2226 2e00 262f $....$&..."&..&/
0x0170: 2a28 2a22 1f2c 2e26 4322 3522 0c22 2f22 *(*".,.&C"5"."/"
0x0180: 2224 261c 311f 241c 0018 1c2a 180c 1c26 "$&.1.$....*...&
0x0190: 1826 1826 1c35 1f22 2424 1f26 2e24 1322 .&.&.5."$$.&.$."
0x01a0: 0c1c 1c18 222c 2b2f 1300 2b2b 1813 1f00 ....",+/..++....
0x01b0: 0c00 1818 0c00 0c0c 8800 fbbb 0000 6322 ..............c"
0x01c0: 0d4d dc44 0c13 0013 0000 0000 1800 0c00 .M.D............
0x01d0: 1c0c 1c00 182b 2e13 0c26 221f 1c1c 281c .....+...&"...(.
0x01e0: 2228 1f1f 0c18 1c1c 1324 220c 1813 2600 "(.......$"...&.
0x01f0: 1813 1800 1813 2218 131c 0c18 1313 131f ......".........
0x0200: 1c1f 0c1c 4d1c 180c 221f 1c00 1f1f 220c ....M...".....".
0x0210: 2a0c 1f1f 001c 1c1f 1c22 181c 130c 001f *........"......
0x0220: 1f18 241f 181c 2626 2400 2226 0013 1813 ..$...&&$."&....
0x0230: 001c 2f2b 220c 0c22 0c00 1318 1c0c 2200 ../+".."......".
0x0240: 1300 0013 0800 f8bb 0000 8008 2c2c 08ce ............,,..
0x0250: efbe adde efbe adde efbe adde efbe adde ................
0x0260: efbe adde efbe adde efbe adde efbe adde ................
0x0270: efbe adde efbe adde efbe adde efbe adde ................
0x0280: efbe adde efbe adde efbe adde efbe adde ................
0x0290: efbe adde efbe adde efbe adde efbe adde ................
0x02a0: efbe adde efbe adde efbe adde efbe adde ................
0x02b0: efbe adde efbe adde efbe adde efbe adde ................
0x02c0: efbe adde efbe adde efbe adde efbe adde ................
0x02d0: efbe adde efbe adde efbe adde efbe adde ................
0x02e0: efbe adde efbe adde 0000 0000 0000 0000 ................
0x02f0: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0300: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0310: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0320: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0330: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0340: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0350: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0360: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0370: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0380: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0390: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x03a0: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x03b0: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x03c0: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x03d0: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x03e0: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x03f0: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0400: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0410: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0420: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0430: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0440: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0450: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0460: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0470: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0480: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0490: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x04a0: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x04b0: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x04c0: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x04d0: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x04e0: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x04f0: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0500: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0510: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0520: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0530: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0540: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0550: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0560: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0570: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0580: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0590: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x05a0: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x05b0: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x05c0: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x05d0: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x05e0: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x05f0: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0600: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0610: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0620: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0630: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0640: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0650: 0000 0000 0000 0000 0000 0000 0000 0000 ................
0x0660: 0000 0000 0000 0000 0000 0000 ............
03:22:06.258258 unknown 802.11 frame type (3)
03:22:06.258278 BA RA:a6:46:8d:1a:4d:12
03:22:06.258289 unknown 802.11 ctrl frame subtype (5)
03:22:06.258301 Request-To-Send TA:ab:46:8d:1a:4f:9d
03:22:06.258311 unknown 802.11 ctrl frame subtype (5)
03:22:06.258321 Request-To-Send TA:aa:46:8d:1a:4f:9d
03:22:06.258331 unknown 802.11 ctrl frame subtype (5)
03:22:06.258343 Request-To-Send TA:aa:46:8d:1a:4f:9d
03:22:06.258354 Clear-To-Send RA:aa:46:8d:1a:4f:9d
03:22:06.258365 unknown 802.11 ctrl frame subtype (5)
03:22:06.258375 BA RA:aa:46:8d:1a:4f:9d
--- End Of Stream ---
GIdenJoe
That's the wireless capture which will not reveal the radius communication.  You have to change the capture interface to wired for that 😉
Also when you want to capture the radius communication on the wired port please use following capture filter: port 1812
The reason your AP can't get a response from the radius could be because it received another IP address from DHCP?  Each AP individually is a radius client.
Keith_Li
i did the following capture, after completed, i couldnt find any data related with port 1812, shall i upload it and you can take a look for me ?
GIdenJoe
You didn't need the host , only radius communicates on that port.
If your AP does not send anything when the client connects to it (so be sure it is a new session, not a roam) then the AP is not doing anything towards the radius servers.
Another important note though:  Dashboard captures can be a bit finnicky and it is possible your capture stopped capturing packets a long time ago.  It is best if you use dashboard captures that you keep to the 30 seconds to 60 seconds mark and immediately try to connect.
