Kindly inform us what will be the main reason of following authentication errors of meraki AP's connection logs. I'm using MR33 APs.
1.Client failed during the authentication step.(reason='reserved' radio='0' vap='0' channel='11' rssi='47)
2.reason='eapol_timeout' radio='0' vap='0' channel='11' rssi='45'
Solved! Go to solution.
The same thing is happening to us and others in the community, and I was told that Meraki confirmed an issue.
I think #1 can be just a wrong password saved or someone trying passwords or just a failure due to something happening mid authentication like walking away or closing laptop, etc. #2 I think is related and is indicating the 4 way handshake for authentication failed possibly for the same type of reasons.
We are seeing some similar random failures on some APs and devices recently, did Meraki say what MR software version was affected? We are running MR33s and MR28.5, upgraded a few months ago.
Meraki Confirmed an issue and the solution could be?
I have users experiencing this error with the a PSK. The password is entered correctly.
MR42s running MR 28.6.1
