@SoCalRacer Thanks for the offer.
For example, we have 30 libraries, and ideally I would like to manage them in the same dashboard network (all of the AP's in one network), however, as some libraries close at different times and open different days, we have been asked to only make the public wifi available when each library is open.
Therfore I have about 5 different schedules for the same SSiD, but in order for that to work, I have to have 5 different networks, each a clone of the original (same ssid), but each with a slightly different schedule applied to that SSiD (on/off time)
I would like to have all in one network but be able to apply different schedules in the form of tagging certain AP's. Howver, in the dashboard you can only apply one schedule per SSiD
I think I'm snookered on this, and will have to continue as is, but if you can think of a way that'll be much appreciated
cheers
