@NolanHerring Yes Nolan, we do indeed still run v24.12 on our MR16's. There seems to be some confusion on that, support can and do allow customers to roll back to older versions, but it would seem that others are not getting that option.
My point is that once a security flaw is indentified will they patch older versions ? I suspect not, it'll just be on the latest version. And if they do patch older versions, it will mean support will have go under the hood to 'upgrade' those ap's to theat old-new version as it won't be on the dashboard
or they could just replace the hardward FOC if it's no longer 'supported'...I'm still wondering what will happen when these older ap's go end of support, this https://meraki.cisco.com/support/#policies suggests the hardware will be replaced...
