Packet Capture causes all clients to disconnect from AP
watdee
When ever I do a packet capture on an Access Point Wireless interface, all clients are disconnected from the AP which is an MR45 running firmware 26.4. Anyone know why that would happen?  I'm trying to diagnose abnormal traffic coming from a specific host.
NolanHerring
The 3rd radio is the one that should be used for packet captures like that.
I would open a case with support as this seems like a bug, with the MR45/55 being new models on beta code, also try 26.5 to see if that helps.
Nolan Herring | nolanwifi.com
TwitterLinkedIn
NolanHerring
TwitterLinkedIn
watdee
It seems like 26.5 may have resolved the issue.
DarrenOC
Did you manage to raise a case with support?  What kind of packet capture are you running, I.e “whole ball of wax”?  Shouldn’t affect your connected devices though running a capture, does sound a bit buggy
watdee
Clicked on a wireless client, then packet capture.  Accepted the defaults and hit start capture.  Only Switch ports seem to have the "Whole ball of Wax" option.  Haven't started a ticket yet.
