New Wireless Stable MR31.1.6
rhbirkelund
mportant note
Bug fixes
  • General stability and performance improvements
  • MR56 ethernet port flaps occur when connected to C9300-48UN(V04) at 5Gbps speeds
  • MR57 ethernet port flaps occur when connected to MS355 at 5Gbps speeds
  • MR46 not responding to Probe Requests from clients
  • Channel & power not configurable via LSP on CW9163E APs
  • Wildcard NAS-IPv6-Address AVP sent on config change (Wi-Fi 6, Wi-Fi 6E APs)
  • NAS-IP-Address discarded (Wi-Fi 6, Wi-Fi 6E APs)
  • RADSec authentication failures (Wi-Fi 6, Wi-Fi 6E APs)
  • Sporadic packet loss & instability on Layer 3 roaming & Teleworker VPN SSID's (Wi-Fi 6, Wi-Fi 6E APs)
  • DHCP offer is not forwarded if broadcast flag is set (Wi-Fi 7 APs)
  • mDNS traffic blocked (Wi-Fi 7 APs)
  • SSIDs broadcast on 6Ghz despite being disabled when using WPA3 transition mode (Wi-Fi 7 APs)
rhbirkelund
Yeah, okay - new and new... Upgraded to Stable from Stable RC, I suppose. I didn't notice. XD
Looks like @Mloraditch  had it first. XD
Inderdeep
@rhbirkelund  Thanks for the update, One thing i would like to ask you how to put the URL in the signature as clickable .. i don't know where the settings are ?
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
rhbirkelund
Good ol' HTML tags. 🙂
<a href="https://www.linkedin.com/in/rbniel/">LinkedIn</a> ::: <a href="https://blog.rhbirkelund.dk/">https://blog.rhbirkelund.dk/</a><br /><br />Like what you see? - Give a Kudo ## Did it answer your question? - Mark it as a Solution :-)<br /><br />All code examples are provided as is. Responsibility for Code execution lies solely your own.
Inderdeep
Awesome bro, Thanks
