Endpoint Management Enrollment Splash Page Stopped Working
bigg_thed
I have an SSID configured to use the Endpoint Management Enrollment Splash Page with SAML enabled on Systems Manager network. I am using a walled garden to allow access to MS login pages and gooogle/apple play store for download of Systems Manager app.
I was testing and I was able to authenticate successfully a few times and then the splash page suddenly stopped appearing. I tried with a few other mobile devices (iOS and Android) and each of the devices simply connected to the network without any splash page. The walled garden still works however. Why would the splash page stop appearing for authentication?
As far as I can tell no changes were made from when it was working. I attempted to disable/enable the network and still having the same issue. Any ideas would be appreciated.
2 Replies 2
ConnorL
Meraki Employee All-Star
I'd recommend opening a Support case if you haven't already @bigg_thed, probably quite a few variables at play here.
bigg_thed
Yes, will be doing this today. Was my first time setting this up so just wanted to see if i was missing something. Thank you.
