Meraki Supported Antenna Chart
rhbirkelund
At one point today I found myself needing a quick overview of supported antennas for different Meraki APs.
Rather than trawling through all the datasheets every time, I've compiled this chart.
Let me know if there are any errors..
Information in the chart is based on current datasheets..
2021-09-09: Updated as per comments.
8 Replies 8
Inderdeep
@rhbirkelund : Good share buddy !
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
You are a star!
KarstenI
Great, thank you for this!
rhbirkelund
I’m pretty sure the MR84 supports the Cisco stadium antenna as well though, but it’s not in the datasheets, so I opted to leave it out.
KarstenI
It is mentioned unter "ordering information" in the MR84 data sheet:
https://meraki.cisco.com/lib/pdf/meraki_datasheet_MR84.pdf
rhbirkelund
Hm
MA-ANT-23 datsheet doesn't mention MR84 as supported, but the MR84 data sheet says that MA-ANT-23 antenna is supported.
Perhaps @CarolineS or @MerakiDave can shed some light on this? Perhaps the data sheets need a refresh.
CarolineS
Meraki Alumni (Retired)
@rhbirkelund wrote:
Hm
@rhbirkelund - I'll pass this on to the appropriate team! Thanks for the heads up.
Rodrigo_
Hi Everyone
This technically works if all antennas are the same. (using that antenna)
However, you would lose 5Ghz band which is a big drawback.
You can find more info 🙂
You should never use single-band antennas on a dual-band antenna port. It will work only for that single band and you will have bad behaviors everywhere else.
All antennas in these kind of APs should be the same.
